Stuck upper control arm bolt
FieryBronco
john
Rochester, NY
How do you Get the upper control arm bolt out? It won’t budge. I have hammered at the bottom many times. At a loss now.
Ford Bronco Stuck upper control arm bolt IMG_7055
Felix808
SRV CA
That would be a broken ball joint my friend.
Use PB Blaster and a hand sledge if you don't have an air hammer 🤠
edit: A "C" clamp style ball joint press should work as well.
RallyGorgo
George
Spencerport, NY
2023 Ford Bronco Badlands
WOW!!! That’s NOT good!!! If I had that issue I’d be be considering pulling the knuckle off and using a balljoint tool to put some pressure on it while beating on the knuckle with a 5-lb hammer. The balljoint tool looks like this:
Ford Bronco Stuck upper control arm bolt IMG_9447
If you can put the tool on and still have room to swing thd hammer you may not need to pull the knuckle. Be careful that you don’t swing the knuckle out too far as you can pull the cv-joints apart unintentionally, then you’ll have more work ahead of you.
Felix808
SRV CA
I don't think that tool is going to be of much help as the head of the ball joint went bluetooth :unsure:
you need a "c" clamp style with the cup
Ford Bronco Stuck upper control arm bolt 1747585319314-tc
FieryBronco
john
Rochester, NY
Ordered the C-Clamp with the cup. I tried stacking an impact socket over the the top with a nut on the bolt on the bottom with a regular clamp, got sketchy pretty quick.
Fordified1
Bob
Mid South Texas
You’re supposed to smack the side of the knuckle to get it to release from the taper.
Felix808
SRV CA
Yeah but if there is no pressure from the upper control arm pulling up on it, it makes it a whole lot harder for that technique to work :sneaky:
Fordified1
Bob
Mid South Texas
Yes I meant while using one of the separation tools. Or if there was someway to smack the side and from the bottom at the same time, which would be really hard to do.
Felix808
SRV CA
In a rust free state, you can usually just smack the knuckle when the ball joint is in tact & they will release without having to use a puller. I can't speak to our salted road friends 🤠
FieryBronco
john
Rochester, NY
This tool worked! I had to use my foot against a wrench to really turn it.
je1279
Upstate NY
2025 Bronco Badlands Sasquatch
Did the ball break off during a suspension install? If so, what happened?
