tap into the courtesy lights when you open the doors
kball
Ken Ball
South Carolina
2022 Base Bronco
i wish to add lights to my steps/running boards and want them to come on when the doors are opened, looking for info on which wire set/fuse connnetion to tap into, tks
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I hadn't thought about this concept until you just mentioned it. It would be cool if you could have your rock lights come on as well. Light up the whole night. If you could tap into the power signal for the puddle lights, that would be neat.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I think @Dom has the right idea. Even if your Bronco doesn't have puddle lights, this thread tells how to add the functionality:
https://www.bronco6g.com/forum/thre...mid-package-bd-side-mirrors-video-added.44411
I know that's a lot of fiddling for some folks but it looks like the interior lighting signals are digital (LIN) so unless you physically tap into the light "socket" itself then just splicing to that wiring isn't going to work. If it's low current (LED) then it'd probably be OK to tap into the door ajar switch wire which provides a ground to the Body Control Module and Driver Door Module to let them know the door is open. I'm not sure if it's grounded when the door is open or closed so you'd need to probe it first to see. If it's grounded when the door is open then you can just wire your lights to a fuse and use the door ajar tap as your ground. If it's grounded when the door is closed then it gets a little more involved.
