- First Name
- Craig
- Joined
- Sep 10, 2023
- Threads
- 6
- Messages
- 262
- Reaction score
- 459
- Location
- Hermann, MO
- Vehicle(s)
- Bronco
- Your Bronco Model
- Badlands
Install a weight distributing hitch and adjust it till your bronco sits level and you probably won’t even know it’s behind you unless you have a strong crosswind. The 2.7 is a premium towing engine in the F150s so power will not be an issue but stability could be under certain conditions.I have a 4dr base Sas, 2.7. Installed the curt hitch, and will add a brake controller as well.
I’m looking into buying a 17’ Casita spirit trailer, dry weight is 2480lbs. I don’t plan to carry much in it, and not filling the water tank. So it should stay under 3k total trailer weight.
Family of 3, maybe 4 some day, and gear in the bronco.
Would this put it too close to limits to be comfortable towing? I know it has the power to pull more weight, but obviously lots of other factors at play here.
Currently I tow a 1,500lb off road trailer with no issue. Had my boat (probably close to 3.5k lbs with trailer and fuel etc) with no issue but only short mostly flat distances on that.
thanks for sharing your experiences/ thoughts.
one thing I just noticed is their tongue weight is published at 365lbs too.
