Towing a car on a dolly with a Bronco
Bryanm
Bryan
Raytown Mo.
2021 Ford Bronco big bend/2022 Badlands
Has anyone towed a vehicle on a dolly with a bronco? Just finished our trip to moab offrodeo and my son has found a project car he wants to haul home (kansas city). So my question is has anyone towed a vehicle on a car dolly 900 miles with a 2.3 bronco and and concerns or advice? The car being towed will be a 1983 RX7 minus the motor and transmission. So well under the listed limit of 3500lbs.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Should not be an issue as long as the tow dolly has surge brakes.
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Should be fine, just check the tire straps on the tow dolly regularly they have a tendency to loosen especially on long trips.
Bryanm
Bryanm
Bryan
Raytown Mo.
EDIT::::: 972 miles later and I can say that the bronco towed very well. Did go with a full trailer over the dolly.
1970AMCAMX
Robert
Titusville, FL
Can't believe Uhaul let you use a trailer, between the soft top on the Bronco and the dry weight of the trailer being 2250 lbs, that only leaves 1250 lbs for the car. My Uhaul rental place is a stickler about not exceeding the tow limit of the vehicle and about towing with a soft top. You must have got lucky where you rented it.
