Timestamp Timezone?
FTBronco9
F-150
Anyone know what the time zone is for the reservation timestamp?
FTBronco9
FTBronco9
F-150
FTBronco9
FTBronco9
F-150
Verified with Ford. All timestamps are set in eastern standard time.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
To determine your exact reservation date and time stamp in Ford's system, refer to the post below by @rtaylor (clipped from another thread)...
Enable chrome developer tool, navigate to your detailed reservation on ford.com, then search on your reservation number. Time of reservation checkout in UTC (2:01:29 UTC in example).
I am not a web developer, but here is the procedure that I used to replicate Mr. Taylor's Chrome example above in layman's terms:
1. Login to your account on Ford.com using the Chrome web browser.
2. Navigate to your Bronco reservation.
3. Hover the mouse cursor over this screen, then right-click and select "Inspect".
4. Select "Network" in the inspection pane that opens to the right.
5. Search in the "Filter" box for your reservation number.
6. Search for the line labeled "created:"
7. Make a note of your timestamp in Ford's system (listed in UTC).
8. Then search for a time zone converter to convert the UTC time stamp to your preferred time zone.
For example, to convert from UTC to CST...
https://savvytime.com/converter/utc-to-cst
I am certain that you can do this with other browsers, but this is the procedure that I used in Chrome.
redcatcher27
Bert
Peachtree City, GA
1997 Ford Expedition
Thanks so much for the information, but that didn't work for me. I'm not sure why, perhaps because I have already placed an order, but at least it got me headed in the right direction. Here's the way that I finally found my timestamp...
5. Hit CTRL+R to reload the page.
6. Scroll down through all the "Names" under the "Name" column, until I came to the third "reservations". (the first two didn't have the information that I was searching for)
7. On the right side of the screen, select the "Preview" tab.
8. Open all the carrots (little triangles) by clicking once on each one - I found the information embedded under "orders" - then "orders" - then "0" - then it was listed under "created"
(2020-07-14T11:03:47+0000)
I'm not sure why, but the filter function described in your post was not getting me there.
Despite the information above about all orders being in EST, if my memory serves me correctly, I placed my order around 6 am EST, which correlates to a UTC timestamp for me.
Good luck to everyone in determining the timestamp that Ford has for them!
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
This worked perfect for me. 2020-07-14T02:33:25+0000. Translates to 7/13/20 at 10:33pm ET which was exactly when I received my email from Ford.
Cousin Eddie
Jack
Pennsylvania
Cadillac
This worked for me...
created: "2020-07-14T08:20:45+0000"
I'm in EST. Time from my confirmation email is...
Tue, Jul 14, 2020, 4:22 AM
KANE COUNTY ILLINOIS
SAL
GMC YUKON
Unfortunately, this hasn't worked for me! I received my email from Ford on 07-13-20 at 11:59 hrs., Chicago time! So UTC time must have moved me into the 14th, correct?
Unfortunately, this didn't work for me. I received my email from Ford at 11:59 pm Chicago time on 07-13-20, but the actual reservation reads 07-14-20!
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
redcatcher27
Bert
Peachtree City, GA
Its my understanding that July 13th, at 8:00 pm EST was the earliest possible reservation. That timestamp would have actually been July 14th at 0000 UTC, according to what I've seen. So the earliest possible timestamp is "2020-07-14T00:00:00+0000".
The email that you received from the dealership that you reserved with could probably have been an hour or so after that.
j_marinelli
Spring Branch, TX.
I was having trouble once I got to the Preview tab but then went over to the Response tab. There, I found my time stamp for reservation and time stamp for converted order.
DeltaBravo
Delta
MIKES MOM
reserved mine at 1020pm EST 7/13. Woot
buildbigboats
Gordon
Chicago
2019 Subaru Forester
This matches up with what my dealer told me my timestamp is when I converted my reservation. My reservation email from Ford has 3:40 PM. I'm on central time. Per dealer timestamp is 4:40 so that would be eastern time.
