- Jan 21, 2021
- 103
- 366
- 356
- New Orleans, LA
- Website
- www.oraclelights.com
- Bronco
- Base
ORACLE Lighting has released many new, innovative Ford Bronco products this year. From triple LED fog lights to flush tail lights, these products will get your Bronco ready to impress and perform both on or off the road. Keep up with the new Bronco products added this year, and more next year to take this tough and impressive vehicle to the next level. Check out our EARLY ACESS to new products here.
BRONCO OCULUS HEADLIGHTS
Your headlights are a critical part of keeping you safe when driving in lower visibility conditions, so when you start looking into upgrades for your Bronco, headlights are a logical place to start. ORACLE Lighting’s Bronco Oculus™ Headlights are a major upgrade for your ride. Our focused LED design helps reduce glare for other drivers due to its high-precision sharp cut-off line, especially on raised Broncos where this is a particular danger. At the same time, these super bright Bi-LED projector headlights provide you with greatly enhanced visibility. Our Oculus headlights have a modular design, which means that you can install the turn signal, marker lights, and mounting tabs separately. The modular design condenses into a smaller package for shipping, reducing your shipping cost and the likelihood of damage in transit. Additionally, the modular design allows for you to upgrade or replace any of the individual components as needed. Get ready to see and be seen like never before with ORACLE Lighting’s Bronco Oculus™ bi-LED projector headlights.
BRONCO FLUSH MOUNT TAIL LIGHTS
ORACLE Lighting has designed new flush mount tail lights for the Ford Bronco, which can help you avoid a common problem that Bronco owners encounter when they go off-roading. The flush mount design helps prevent the kind of damage that can happen to the factory lights, which stick out three inches, on the trail. This simple upgrade will help you enjoy off-roading without having to worry about damaging your tail lights with obstacles such as branches that you may have missed. These flush mount tail lights feature high-powered LEDs for a lot of brightness and they wrap around the edge of the vehicle for maximum visibility so you can back up safely, making them useful even on the road, in parking lots, or in your driveway. Like many of our products these lights are easy to install so you can get back to driving right away. The sleek design of these tail lights along with their brightness will make your driving safer without compromising the look of your vehicle.
BRONCO TRIPLE FOG LIGHT
One of our most exciting new Ford Bronco accessories, ORACLE Lighting’s Triple Fog Lights for the 2021-2022 Ford Bronco are designed for the factory modular steel bumper on these Bronco models. These lights comprise three forward-facing LED lights that feature six high-powered emitters with a 6000 raw Lumen output. These triple fog lights have a blacked-out look with a powder coat finish for a unique appearance, while also avoiding glare. They even have a waterproof rating of IP68. As with many of ORACLE Lighting’s products, this triple fog light installs in factory bolt locations, making it quick to install without any drilling or modifications, and using the tools you have in your garage. The fog light kit includes 2 assembled steel housings, 6 LED Emitters, Wiring Harness and all hardware needed.
BRONCO LED OFF-ROAD SIDE MIRRORS
The Ford Bronco is designed to be an off-roading machine, so if you’re ready to head out off the beaten path, make sure you have the equipment you need to stay safe and enjoy the ride. These LED mirrors for off-roading have the brightness that lets you see obstacles you might otherwise miss, and as they’re positioned on the side mirrors, they increase peripheral visibility without obstructing the driver’s line of sight. Unlike light bars that attach to your bumper or roof rack, our off-road side mirrors are created to blend into your vehicle design and retain an almost factory look, so they won’t get in the way while they get the job done.
UNIVERSAL ILLUMINATED LED LETTERS
Customize your vehicle with a vibrant new look with universal LED letter badges from ORACLE Lighting! These individual LED illuminated letters for cars are the perfect way to make your own marquee-style glowing vehicle badge. When turned on, the letters emit a soft edge-lit glow to make your custom badge stand out. Even when off, the sleek design of the letter housings gives a customized high-end appearance. The premium construction and overall styling deliver great value for an easy DIY illuminated badge. Simply choose the letters you need, and get ready to draw attention to your ride with a build-your-own glowing letter design!
BRONCO INTEGRATED WINDSHIELD ROOF LIGHT BAR SYSTEM
If you are in the market for a high-mount LED Light bar and want to retain an almost factory look, the new ORACLE Integrated LED Light Bar is for you! While other offerings look obviously after-market or like an after-thought, our Patent-Pending design with its molded cowling integrates into the factory roof line. This product further adds to the rugged and practical style of your 2021 or newer Ford Bronco. Along with blending in with the factory design, the unique cowl design also provides a quieter and more aerodynamic installation compared to traditional LED light bar setups. The polycarbonate housing is designed to match the styling of the factory hardtop but can be installed on soft top Broncos as well, it even retains all functionality when you might want to go topless!
