Has a plug and play option come out yet for those of us without led taillights? Flat 4 prong plug works for me. Thanks!
Hold on a minute.....as I was just now looking again, it looks like Tekonsha now has TWO different part numbers on their website. The only I linked above says " Ford, Bronco, w/LED Taillights " but now they have a second part number that shows as " Ford, Bronco, Except w/LED Taillights " so that could be the ticket!I don't think so, not that I have seen anyway. Both the Tekonsha and Curt options still show on their websites as LED only:
Tekonsha: https://www.tekonsha.com/product/118849_tow-harness-t-connector-assembly#product-fitguide-content
Curt: https://www.curtmfg.com/part/56468
As you may know however, these can be pretty easily modified to work with halogen style tail lights.
Who wants to be the Guinea pig?!?!Hold on a minute.....as I was just now looking again, it looks like Tekonsha now has TWO different part numbers on their website. The only I linked above says " Ford, Bronco, w/LED Taillights " but now they have a second part number that shows as " Ford, Bronco, Except w/LED Taillights " so that could be the ticket!
https://www.tekonsha.com/Product/118867_tow-harness-t-connector-assembly
Can’t find it for sale anywhere online.Annnnd did some more searching and Curt now has one too: https://www.curtmfg.com/part/56471
application says " Note - Without LED taillights "
Try real truck.com...but note somebody told me the following: The only place I could find it is Realtruck and they have a problem on their website - so if you try to order it - it will try to swap you out to the wrong part number. The only way to order this I can find is a direct call to Realtruck and explaining to them there is a problem with their lookup.Annnnd did some more searching and Curt now has one too: https://www.curtmfg.com/part/56471
I only see one Curt option on realtruck and it doesn’t have the part number orSay anything about led or non-led. Another reason to call.Try real truck.com...but note somebody told me the following: The only place I could find it is Realtruck and they have a problem on their website - so if you try to order it - it will try to swap you out to the wrong part number. The only way to order this I can find is a direct call to Realtruck and explaining to them there is a problem with their lookup.
