- First Name
- Cole
- Joined
- Dec 8, 2021
- Threads
- 6
- Messages
- 367
- Reaction score
- 1,461
- Location
- California
- Vehicle(s)
- 2021 First Edition
- Your Bronco Model
- First Edition
- Thread starter
- #1,396
We actually borrow a technique used in aerospace and use a honeycomb somewhat similar to factory but the major difference is it is completely coated in resin and allowed to dry before we put the final layer of fiberglass.@Turn Offroad @TURN Todd What is the interior cavity of the top like? Similar to the OEM top or does it have an injection foam similar to those other guys that can't seem to actually produce a top?
This adds a lot of material costs to the production which is why they skip this with the OEM tops but the result is what makes our tops so strong. It’s also really good insulation because of all of the tiny pockets of air.
The problem with the OEM top is that they lay it all up super thin and then the cardboard that they put in the middle is completely dry and not at all penetrated with resin. This makes production cheaper but doesn’t create nearly as durable of a product.
The OEM top has given the use of honeycomb a bad reputation but when executed correctly it really is the most tried and true way to build strong fiberglass parts. It’s used everywhere from space shuttles to the blades on wind driven generators.
Foam doesn’t provide any support or rigidity and basically just fills a gap left after gluing the inner and outer portions of a product together.
Hope that helps shed some light!
