USB A and C port not working (Near wireless charging pad)
Bronkyto
Santa Monica, CA
2022 Bronco 2022 Cayenne S
Hello all,
have not been able to get the usb port near the wireless charging pad to work since picked up my Bronco a year ago. Dealers in LA want the truck for at least 4 days to “diagnose” which is not practical and trying to find a solution if can fix on my own. Any help would be appreciated. Ford service is pretty much worthless.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
My wife’s explorer had the same problem. My dealer fixed it in an hour
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Hello all,
Have you checked the fuse?
It is a warranty issue. Ford's service is not worthless...the dealer you went to falls into that category. Make an appointment with another dealer. I would think it is an easy fix...one of those wait in the lounge when they do it kinda fixes.
j_marinelli
Spring Branch, TX.
Hello all,
Mine has not worked since day one either (will be 2 years in Oct.). I have tried to get it in a couple times to have them look at it but what happens is I have to get it on their schedule which is usually about 10-12 weeks out and then they tell me they will need it for at least a week to diagnosis it. Ultimately I have been content with the wireless android auto connection and I just run a charger from my center console.
Bronkyto
Santa Monica, CA
Plan to do this later today. Based on the fuse box seems to be fuse 125 or 139 I believe.
Bronkyto
Santa Monica, CA
This is exactly what’s been going on for me. Have called 5 nearest dealers with the same expectation. I have also been running the wireless charger and dash at times where need a faster charge. At this point if a cheap fix rather do it myself than waste a week at the dealer
EruptionEnvy602
Phoenix, AZ, United States
07 explorer
Just checked all the fuses that the diagram indicates are for the usb/aux power. All are good. Yesterday my son was charging while playing pokemon go and said "it stopped charging". Power to the (aftermarket) wireless charger pad also went out.
I'll remove the wireless charging pad to see if it or one of its wiring harnesses is the culprit, since it is aftermarket. Hoping that it's just a case of mabbett quality. Now I just need to find the factory plastic tray.
