Vibrations after installing RC spacer lift....
Krak-A-Pat
Jordan
Houston
'23 Black diamond
I had rough country spacer pucks installed on my 23 BD along with 34" A/T's. about three days after having it installed I drove out to a mud park and went mudding and some slight 4 wheeling around. The mud was THICK. when I got back on the road my Bronco shook like crazy at 50mph and above. Once all the mud had been cleaned from the wheels and everywhere else I am still getting vibrations at around 65mph+ and they only get worse the faster I go. It's not terrible but you do feel like you're fighting the wheel. I had it sent back to the garage that installed the lift and aligned my ride. They drove it and said everything was fine and it was just b/c of the mud.... but it still vibrates after being thoroughly cleaned... Does anyone else have this issue after installing the RC suspension pucks? Or any idea what might be causing this?
Theherofails
Thomas
Phoenix
This is an IFS vehicle so there is no true ‘death wobble’.
You need to take it back ASAP because the chance is there that something in the steering is incredibly loose. Tie rod inner/outer, knuckle, something..
Another possibility is you threw your wheel weights and your tire is really unbalanced.
Yet another option is you screwed up your toe and your tires are scrambling for traction but you should see your traction control light flashing occasionally and feel a loss of power.
Check your tires for wear - if you tore off a lug or something, it would cause this issue
You can get an idea of where you stand by jacking the front two tires off the ground and shaking/wobbling each wheel top to bottom and left to right to see if you feel any play.
If you can’t get the tire and wheel to wobble at all, that’s good.
Mudding is incredibly hard on vehicles, so expect the occasional problem. Nothing you shouldn’t be able to handle.
Keep an eye on your tie rod boot seal - one leak is enough to trash your steering rack but that’s true for any rack/pinion setup.
Mud wiped out my factory rack after about 18 months.
Jdyount
Kansas
2021 Badlands
Probably threw a wheel weight or you still have mud on the back side of the wheel. Take the tires off and make sure you clean the inside face.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Was it Xtreme Off Road or General Sams? Mudding can be very fun... in somebody else's rig.
@Theherofails I think covered the possibilities pretty thoroughly. A wheel weight or some out of whack steering seems the most likely.
Not sure if a warranty service will cover it if there's evidence of excessive wear; if you're looking for somewhere to take it for alignment, I'd recommend Firestone, which has 1yr and lifetime alignment options. If you go that route, make sure and take it in during the week so an A tech does it.
rtaylor
R
ID
19Raptor, 22Bronco
If vibrates in both 2H and 4A it is likely a simple wheel balance issue (get tires/wheels checked and rebalanced). If worse in 4A, then it could be more serious (CV axle).
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Sounds like a wheel out of balance. Probably lost a wheel weight or two
Krak-A-Pat
Krak-A-Pat
Jordan
Houston
'23 Black diamond
General Sams. I read the other thread as well looks like he gave up. Ill check balance
Donkeygyrl
Sheri
San Francisco
Bronco on order
Either weights got thrown ,or you missed a chunk of mud on the wheel somewhere.
Krak-A-Pat
Krak-A-Pat
Jordan
Houston
'23 Black diamond
