- Nick
- Jan 23, 2021
- 8
- 83
- 274
- Central Illinois
- Website
- www.youtube.com
- Ford
- Outer Banks
I did the passenger side while my friend James who is a tech at my dealership did the driver side. So yes, "We" would be correct. Quicker to get done with two people."We" in the tittle should be replaced by "I paid Ford".
We followed the instructions from Icon which did not include removing the CV from the hub assembly.Please tell me you edited out the part when the CV was disconnected from the hub and didn't leave it installed as you did the other work.
Got lucky if he didn’t pull the joint apart.. didn’t watch the video thoughPlease tell me you edited out the part when the CV was disconnected from the hub and didn't leave it installed as you did the other work.
After seeing some of the posts with lifts and failed CVs, my theory is that people are taking a short cut or the shitty directions that came with the lift skip this step. I suspect they do this because getting the stub out of the hub, extra tooling/skill required, may scare some DIY folks away. Don't know that for sure but that's my opinion. The Ford workshop manual (front shock removal), in step 3, right after remove wheel, clearly says to remove hub nut and push the axle back. It can obviously be done without removing but it's specifically done in this order to prevent hyperextension of the joint and boot.We followed the instructions from Icon which did not include removing the CV from the hub assembly.
That was one reason I worked with my techs at our service department on it to make sure things went right and so far I've put 10,000 miles in it with no issues.After seeing some of the posts with lifts and failed CVs, my theory is that people are taking a short cut or the shitty directions that came with the lift skip this step. I suspect they do this because getting the stub out of the hub, extra tooling/skill required, may scare some DIY folks away. Don't know that for sure but that's my opinion. The Ford workshop manual (front shock removal), in step 3, right after remove wheel, clearly says to remove hub nut and push the axle back. It can obviously be done without removing but it's specifically done in this order to prevent hyperextension of the joint and boot.
Not trying to bust your balls, just want to see people avoid potential issues and costly repairs. These companies should be following the OEM workshop manual procedures when possible, otherwise they're doing a disservice to their customers.
Wasn't going to bring it up but that's what made me cringe and asked about the editing.That was one reason I worked with my techs at our service department on it to make sure things went right and so far I've put 10,000 miles in it with no issues.
