Where did you buy the new CV axle from? I need one nowI would take a good look at your outer joint on the passenger axle. Ours came without circlip installed. I believe that may have caused our issue. Without the circlip it's very possible the outer axle slipped out of joint when dropping the control arm for install spacer. There is plenty of play on inner joint with 2" RC lift. But I'm beginning to think the suction inside the inner boot may inhibit it from extending the axle shaft during articulation and move to the "Path of Least Resistance", which would be the unsecured outer boot. With no circlip, the least resistance will be the outer joint and the shaft will easily slip from the joint. The inner joint is stuck in a mass of grease. The suction within the boot is noticeable.. (once I got our broken cv home) from inner shaft and pull out of the outer shaft. This wouldn't be possible if the circlip is installed.
https://www.bronco6g.com/forum/thre...-spacer-lift-or-35-tires-whos-to-blame.35457/
Dealership ordered it and installed $1200 they were back ordered off and on, took about a monthWhere did you buy the new CV axle from? I need one now
Hey @JoshuaPrieto2.3l 4 door automatic. I tried seeing if gear mattered but it doesn't. Happens when the vehicle gets to 60 miles per hour or higher, if you happen to let the car coast down in speed it starts a vibrations that is in intervals... like rotations basically. If you go from 80 to 70 from coasting you feel it. Anything after 80 mph or at any speed in 4x4, the vibration goes away. It could be a driveshaft, my mechanic wants to relocate it? I'm not sure what that means, this isn't my expertise area, haha. We do definitely want to put the stock tires/wheels back on and see if that fixes it. First, is trying to see if the angle of what you mentioned is the issue. This weekend we should have time to just kick back on Saturday or Sunday, throw it in the air and do the tinkering(by do, I mean I sit down and look at things that make a car move )my good friend will be doing the work.
It didn't do this before, or when we put the lift on. It happened about two weeks after putting the larger tires on. My service team, were useless to me - all they tell me is it is the tires. Yes, I'm pretty sure that is it... but can I fix it, is what I'm looking for... so thank you for the response! This definitely helps me go into the right direction.
Sadly no update, sorry for not including that, I eventually gave up. In the warmer weather the vibration went away. Only when cold, which led me to believe bad tire materials - but when I did the rotations, it only would stay at the front driver side. We rebalanced them several times, I took them to Discount Tire to have them road force balanced - that didn't work. We took the tires off and the lift, it was still there, but you had to listen/feel for it. More prominent with the bigger tires.Hey @JoshuaPrieto
I've been dealing with this same exact issue for the most part for months. Did you end up finding a solution?
So far I've replaced my front driver side bearing.
I get rotational sounding grinding/hum sound that sounds like its coming from the drivers side front. Two dealership service centers and still no clue.
