Who Else Has Made It To Bronco Knoll?
R1Bronco
R
Ford explore sport
My son and I finally made it to Bronco Knoll along with some friends.....
If you get a chance to visit Johnson Valley do it....You have everything there from sand dunes,dry lake beds open dessert trails to climbing mountains....
R1Bronco
R1Bronco
R
Ford explore sport
It's all open area,just pick a spot
R1Bronco
R1Bronco
R
Ford explore sport
There will be signs if camping is not allowed in any area....
da_jokker
Jeep Wrangler JKUR
BLM land..good to go unless posted. National Forest, usually good to go but should check rules because sometimes permits are needed (like one for camp fires at least)
State parks...I think only is designated camp grounds and with fees.
Felix808
SRV CA
Just tell them you're homeless after buying the Bronco due to the ADM and various other Bronco taxes you had to pay. They let them set up camp anywhere out here :sneaky:
FireBall
Gene
Winston-Salem, NC
F350, Venza, Catalina 22
Yellow trail up. Green trail down. Yellow is fairly steep with lots of loose rocks. No problem with rear locker and 35s. Green is more gradual with several 8-18" ledges. Again, no problem with 35s.
Ford Bronco Who Else Has Made It To Bronco Knoll? Bronco Knoll 001
swooshdave
Portland, Oregon
Mustang
Yup. Those are the ones I took too!
myrealname123
Trent
Monterey, CA
'21 Bronco
I was there last Friday, it was 108 when I was driving out. I took green up and down, no problem on 33s. I did not see a single soul the whole time I was out there, was hoping I'd run into someone.
Ford Bronco Who Else Has Made It To Bronco Knoll? 20230630_141655
myrealname123
Trent
Monterey, CA
'21 Bronco
Did anyone record the height of the knoll?
I forgot to cut my Gaia on when I was going up, but I looked it up when I got home. It is just a shade under 3800 feet elevation and around 400 feet higher than transmission line road.
Coordinates on the screenshot aren't exact.
Ford Bronco Who Else Has Made It To Bronco Knoll? 1688696401941
swooshdave
Portland, Oregon
Mustang
There’s some decent drone footage at the beginning of my video I shot at the beginning of June. I haven’t seen much that shows the scale of the knoll.
The rest of my trip was documented here.https://www.bronco6g.com/forum/threads/a-month-on-the-road-live-updates.74629/
