So you really can't run 35's with the 4.46 gears? What will happen? Sluggish or worse?For me as a mechanic, the Sasquatch package is worth the money. The 4.77 gearing will make the truck drive like a normal truck with 35 tires. Putting bigger tires on lower gearing will affect drivability. If you want to get them installed later you need to get them installed by Ford to ensure they are done right, but even then... there may be an issue with installation. Unless you know a shop that gets gear spacing and lash perfect, I would just rather have it done from the factory. Same with lift and alignment. I’m paying for all that to be assembled right from the factory. Under warranty.
