Yet another remote start 7speed manual
jalexa27
James
Excelsior, MN
1965 impala
I have been watching for any remote start developments as well!
Worst case scenario, I was going to see if there is a "neutral" switch in the transmission or somehow set one up. That way it reduces the risk as it will only turn on or start when in "neutral".
If there is an off the shelf version, totally in!.
Mrplowjr73
Kory
New York
22 BD SAS
I've got a spare 933 fob and transceiver sitting here waiting to install. I haven't torn into it yet to see where exactly it goes. I ordered it just for the off chance it would work.
Not having remote start when you have no less than 2 safeties available to ensure its not in gear and the brake is set just seems ridiculous to me.
smonroe11
Stephen
Dallas
Chevrolet Tahoe
I've got a spate 933 fob and transceiver sitting here waiting to install. I haven't torn into it yet to see where exactly it goes. I ordered it just for the off chance it would work.
Following…
infrared
Larry
texas
22 Bronco, 96 F350, 80 F250
I ordered an RTM from Ford parts for the 902 mhz version. Also ordered the remote start Bronco key fob from the same parts.ford.com website. Cost a total of $105. The RTM is located on the roll bar cross member behind the overhead lamp. I programmed the remote first and then replaced the RTM. Programmed in forscan with the as built data and it worked as a key fob. Remote start is still a work in progress.
DGE1993
SGF-MO
'66 Mustang; '06 F-150; '22 Bronco
Following! I hope you get it figured out and do a write up. Its the last feature I want that wasn't available.
Mrplowjr73
Kory
New York
22 BD SAS
I watched the video, I wonder if it would make any difference having the clutch depressed. Just a shot in the dark but may help eliminate potential issues.
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Wow! I got roasted for suggesting this a few months back.....
ELS
Mustang
Following! If someone finds a work around please let me know!! 🙏
HotLap
Bradley
CA Central Coast
2018 Ford Raptor and 2019 Yamaha XSR900
LMAO, thank for the laugh Butzy, needed that :) Funny how quickly the winds change ;)
E. J
Marc
South Central Kentucky
F150 SCab 4X4 XLT
As mentioned earlier, did pressing the clutch pedal allow the remote start to operate?
infrared
Larry
texas
No. Pressing the clutch did not make this work. It is a combination of having the telematics control module for a automatic plus a bunch of little work around to get it to work. This is dangerous so a working solution will not be published. For those wanting to experiment with the settings, drop me a pm.
Trialmx
Jack
Ohio
2022 Bronco
I Installed Ford's perimeter plus module in my 2022 manual transmission Badlands. The installation instructions have references to manual start capabilities that I haven't looked into further. Maybe remote start with a new key fob and some forscan changes?? I don't think Fordpass phone app would add the remote start "button" since the app is probably linked to as built VIN#.
_2020_
Sylvain
MA
2014 Mini Countryman S , 2015 JKU, 2017 X5 3.5i
After you changed the RTM, how did you add the new key fobs(s)?
Did you have to reconfigure/reset TPMS modules?
