SurfsUp85
Joshua
Windsor, Ontario
Kia soul 4u
No just the leveling kit. I was shocked how much one inch made a big difference. I even had to adjust the mirrors
Nice!
I'm debating raising it one-two inches. Looks awesome!
Advertisement
KEM IA
Kevin
Cedar Rapids
Tundra
Honestly it doesn't look ok with the same color body colors.
pimpjuice
ocala, fl
bronco
Thank you so much for this information. This is exactly what I was planning on doing with my OBX. It's great to be able to see it and take some is the guessing out of it.
Ponyride302
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Thats not a stock wheel either right? Maybe it's got a big positive offset or something giving it a little more room
I learned recently that positive offset brings it in and negative offset pushes it out. Factory offset is +55mm. My wheels will be +18mm to counteract the wider tires I will be running. I am going from 32x10.5 (black diamond build) to 35x11.50.
Pbloom49
Peter
Connecticut
2021 Bronco Outer Banks
Pbloom49
Peter
Connecticut
No positive pushes the wheels and tires away from the axles. This is the wheels I purchased and you can see it is +30 the stock is +15 I think
Ponyride302
Central Virginia
No positive pushes the wheels and tires away from the axles. This is the wheels I purchased and you can see it is +55 the stock is +15 I think
Razorbak86
Northwest Arkansas
Lexus RX 450h, BMW R1150 GS
It’s the opposite, actually. @Ponyride302 is right. Look at his diagram.
Positive offset moves the centerline of the wheel closer to the axle hub. Negative offset moves the centerline of the wheel away from the axle hub (“poke”).
FWIW, factory offset (non-Sasquatch) is +55. Sasquatch offset is +30.
The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes
Lagrange 6g
Tony
Austin , tx
2018 f250 2014 landcruiser 1978 cj5
Shoot you bought the last ones
Advertisement
4x4TruckLEDs.com
Advertisement
