BAUS67
redneck
Central PA
The RC driver’s side bushing WILL NOT work with the Severe Duty/Hoss 3.0 rack. I found that out the hard way today. Not sure about passenger’s side, as I went with a housing that had a bushing.
10-4. I deleted post so not to confuse.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Side note: did you ever manage to program the rack w/procal? Seems alot of folks are struggling w/that!
Migo
Roy
Houston, TX
www.instagram.com
You really don't want aftermarket bushings with the Hoss 3.0. I had some wear on my stock hoss 3.0 bushing and about the same wear on my BroncBuster bushing. Switched to 74Weld bushing and I even regret doing that. Rather just have left it stock and saved the money towards a 74weld full steering rack.
I agree. In retrospect, I likely wouldn’t take the time to do the bushing. The Hoss 3.0 bushing was a bear to get out, which made me think it would survive much longer than the 2.0. With that said, I had the bushing on hand, and by the time I destroyed the factory bushing, I was pot committed. Daily driver modding woes…
Migo
Roy
Houston, TX
www.instagram.com
I was. Completed the install over the weekend. It went pretty smooth, aside from the bushing issues. The programming piece was relatively straightforward, once you get the file onto your ProCal tool.
jh3113
Jake
Phoenix
Subaru Outback
Shot in the dark, but does anyone have an old 2.0 Rack lying they’d be willing to sell me? When torquing down my Stage 1 - 74 Weld housing, one of the T30 bolts just sheared completely off flush with the rack. I am thinking I might need to salvage part of a donor rack to frankenstein mine back to life (if I cant extract the bolt out of the housing, which I am debating if it is even worth my time trying since I’ve never had any luck extracting bolts). Thanks.
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT IMG_1399
Fordified1
Bob
Mid South Texas
So that bolt is broken off in the main housing? Take the outer housing off and cut a screwdriver slot in the broke bolt with a thin cutoff wheel. If it’s too stuck to get with a flathead screwdriver weld a nut to it.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@jh3113
Easiest way is taking it out and apart. Then simply welding a nut on the end (muffler shop) will free it up due to the heat.
FYI your fine to drive it as is for a while, just no wheeling or jumping speed bumps.
heelyeah
Tripp
2021 Bronco; 2022 F150 Lightning; 2021 JT (wife's)
I've got one but I'm in NC. Where are you?
jh3113
Jake
Phoenix
Subaru Outback
Found a left-handed bit set in the garage and was able to extract it really easily without even removing the housing. Yay! Thanks for everyones advice!
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT IMG_1401
Blueberry OJ
Giancarlo
Riverside
2021 Bronco big bend 4D Non-sas, 2016 F150 3.5l EB
Can someone tell me if I just install the new ford performance steering rack, will I be able to drive it to the Ford dealer so they can do the programming? I currently have the Bronco on stands with the old rack out. I have an appointment with ford service set up for Tuesday already. Thanks in advance.
Blueberry OJ
Giancarlo
Riverside
Should I flash the new software at least, that ford sent with the new rack before I take it in?
In theory - since you already have the ProCal tool and tune - once you flash it with that, you are done. No dealer needed.
Blueberry OJ
Giancarlo
Riverside
Thanks for the reply, that's what I'm assuming also...my concern now is that my bronco is a non sas. Their website said this for sas only. Would this bust my bronco?
Here's the procal software paper they sent me.
I asked that same question somewhere around here - and got a reply that it worked. I'm not immediately interested in upgrading my steering rack, but if I ever have issues, I would jump on this.
That said, if it doesn't - I'd be curious to hear. There is a work-around in this very thread that requires both Forscan and FDRS, but I don't know if your dealer will do it or not.
