I was about to purchase a Smitty Built compressor which just needs to be connected to the battery and the tire you want to inflate. I was hoping the Trickflate would be that easy but I see "This compressor is not designed for 1 tire at a time and should be used with a 4 tire hose system" so now I am a little confused to say the least about what is included in the kit and what I need to add.
What is the duty cycle for the pump? I see the duty cycle drops to 2 minutes when inflating one tire.
Does the pump include a way to pump all four tires at the same time or do I need to assemble the hoses to make it work?
Will the Milton S443 3-in-1 chuck allow the filling of smaller items (sports balls, air mattresses, etc) in addition to a single tire?
What is the duty cycle using the Milton S443 check when inflating a single tire?
What configurations would require the use of the Trickflate pressure switch and US style automotive coupler conversion kit or the Trickflate 2 way hose manifold with 0-200 PSI pressure gauge?
