Yeah, hardtops should be very similar.Are they using the same hardtops as regular Broncos? I know it's a wider body but is that just the side panels or fender flares?
Do you have P/Ns?I just received my Raptor tailgate hinges...much beefier than regular Bronco hinges, and tapped for adding a tailgate bracket. I am using an aftermarket bracket and mounting it to the new hinges.
Like everything Raptor it’s tough to say if the top is the same, but I’ve seen nothing indicating it’s different. Probably one of the few things that are the same as other Broncos.Are they using the same hardtops as regular Broncos? I know it's a wider body but is that just the side panels or fender flares?
I thought someone said the hard top was the same, but the soft top would hit because of the added bracing, I can't seem to find the post though.The B-brace and C-Braces could also come into play, but they both appear to be set low enough not to interfere with hard top.
Good point. I think I saw something non-definitive that said soft top could have an issue. Think it was potentiallya problem folding back. I was solely focused on the hard top in the posters questionI thought someone said the hard top was the same, but the soft top would hit because of the added bracing, I can't seem to find the post though.
I figure we wont know for sure until someone gets one and tries both out.Good point. I think I saw something non-definitive that said soft top could have an issue. Think it was potentiallya problem folding back. I was solely focused on the hard top in the posters question
How much did you pay for those hinges and do you thing they would be strong enough to put on a mount for a hi-lift jack?I just received my Raptor tailgate hinges...much beefier than regular Bronco hinges, and tapped for adding a tailgate bracket. I am using an aftermarket bracket and mounting it to the new hinges.
4 doors and those flares = Fugly to the max. Hope the aftermarket comes up with a solution.If you think they look cool now, just wait until they sit in the sun for a few years. Ford really wimped out by not making the actual fenders wider rather than just the flares but I bet massive fiberglass ones will be out by year's end and they'll look sinister
