Angelfromjtown
Angel
Johnstown NY
2021 Bronco Big Bend
This helps a lot. I am looking at Method 305s with +25 offset and 295/70/17 tires. I do not want tires extending beyond edge of fender flares. Thanks.
No problem! +25 should have a little less poke than mine but still look really nice.
Bach007hd
James
Missouri
0 offset Method wheels , 315/70r17 good year wrangler territory tires, crash bar extension removed, no lift. Hope this is helpful if anyone is wondering if it can be done and how it would look with no additional lift on a cactus gray bronco big bend.
Sweet! I'm going with 305's on my steelies when the 265's wear out! 👌😉😎
Angelfromjtown
Angel
Johnstown NY
Got the speedometer / ecm flashed for the 35’s today for 110 at ford. Not sure if that’s a deal or not but it was cheaper than buying a calibrator.
amoraes
Andre
Pearland
CX-5
Would this method work in an Obx non sas?
Bronco-ocnorB
Luke
DFW
Ford Flex
amoraes
Andre
Pearland
CX-5
Angelfromjtown
Angel
Johnstown NY
Mine is not a sas . I have a normal big bend. I just bought the rims, the tires, removed the crash bars that the saw package removes and also had the ecm flashed for the speedometer calibration.
tongsun3717
X3
What is the desirable poke for you? Such as
285 tire and +35 offset = 35mm poke?
305 tire and +25 offset = 55mm poke?
315 tire and 0 offset = 85mm poke?
Will you replace the flares?
R8RWD
TN
Are you happy with this setup? How is the ride quality vs. stock? I have a BB arriving next week, I'll probably duplicate your setup. I'm too chicken, so need to copy off something that's already proven :)
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
What is your gear ratio on this and how does it feel running these compared to stock?
