jclaypool83
PA
Badsquatch, 6.7L 2500 RAM, FOCUS RS
I hope everyone noticed that this isn't compatible with the 2.7l engine. Didn't go through every thread but I see some with build signatures talking about installation.
mpeugeot
97 Ferrari F355, 11 Ford F-150, 06 Suzuki SV1000s
Ya, well that wasn't noted when I purchased mine... So mine should fit. ;) How's that for Autism?!?
mcinfantry
Lee
Louisiana
Lexus/Jeep
Will this fit the capable bumper or is it what and what vs getting it to fit with the modular?
Kameronatm
Kameron
Jeep Grand Cherokee Overland
RC said they will come out with a capable bumper winch mount early next year.
Kameronatm
Kameron
Ok. Trying to figure out what bumper i need to order with my badlands for this to work
well... hard to say exactly but supposedly if you get the capable bumper they are coming out with one next year. I didn't ask about the mod bumper options going forward
mike8675309
Minnesota
2014 ford focus se, 2021 Chevy Traverse
What makes it "work" or not work is related to the bash plate they included with the fairlead.
The mount will fit regardless of the bumper but the fairlead bash plate fits up with only the specific bumper. The one person on youtube who documented his install (2 parts plus a faq) didn't use their bash plate. He cut out the fairlead opening from the rough country bash plate, had an opening cut with a water jet on his existing bash plate, and fit the fairlead to the front of it.
So in theory you should be able to get it to "work" with any bumper. You just need to be willing to do some work or work with a local job shop to get the work done. The key part of their kit is the mount for their winch that works well with their winch to position the controls where you can reach them with the hood open.
Nellman
Josh
Northern California unfortunately
2007 Toyota Tundra
Yeah I can do with out the camera and the acc sensor. In all of my years I've never needed these items anyway. Just offer a camera delete and acc delete with the lux package.
How is that rotary phone working for you? I hope you have at least left the telegraph behind. Just because YOU don't need them doesn't mean that can't be extremely beneficial. The ACC I do believe is making people lazier drivers as they don't have to pay as much attention to the road but then again without it people are already doing that.
The cameras are extremely beneficial. Your way requires multiple people or multiple trips out of the driver seat to safely navigate certain terrain. Unless you are a subscriber to the "back up until it sounds expensive" method. In which case the removable parts are going to be your best friend.
History is filled with people that took your stance. This usually left them behind in the dust. There is a better way to do everything, it may not be available yet though.
redone17
Cold Spring, NY
2021 Bronco, 2016 Transit Connect
Thanks for linking that. I saw his review on the RC site. Was hoping it was documented elsewhere. I know RC makes some iffy products. Wonder if any other brand winches will work.
mpeugeot
Any winch with a standard 10x4 mount should fir up to a 12k winch.
MOON
2011 Jeep Grand Cherokee
Did that fit your 2.7 ok?
SPITmadFIRE
CA
Am I the only one who feels like this sort of trimming will both affect crash safety, and possibly cause the force exerted by the drivetrain to either warp the frame or damage the front diff in some way. From my experience with the RS, you want to bolster the mounts holding the various diffs/drivetrain pieces in place, not trim them back. It's a common issue for RS's with performance tunes to produce enough torque to actually twist the PTU (center diff) and destroy it, quite dramatically. One of the popular mods from Mountune is for reinforcing that mount:
https://www.mountuneusa.com/Focus-Rs-Ptu-Brace-Upgrade-p/2536-pbkt-aa.htm
The difference between the stock mount, and upgraded ones are massive -- I worry that trimming the Bronco's frame around the front diff will dramatically weaken its support as well. These parts of the install instructions worry me:
mpeugeot
Mostly, with the exception of the front heat exchanger that must be relocated (which I haven't done yet). I will probably be tackling that soon enough.
Advertisement
Advertisement
