Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
Hey folks I thought it might be helpful to list all of ICON's Bronco-compatible wheels in one place. Here is every wheel that ICON currently offers that fits the 2021+ Ford Bronco. New styles, sizes and offsets are introduced regularly so I'll try to keep this list updated. Some notes:
  • FINISH: The finishes (colors) are listed in the table in the same order they are shown in the images (left-to-right).
  • OFFSET: Factory Sasquatch wheels are 17 X 8.5 with 30mm offset. ICON wheels with 25mm offset will put the outside of the wheel about 1/4" wider than the Sasquatch wheel. The ICON 0mm offset wheels will place the outside of the tire approximately 1-1/4" wider than the Sasquatch wheel.
  • HUB BORE: All of the wheels listed here will fit and work correctly with your Bronco's hubs. The Hub Bore column simply denotes which part numbers will be hub-centric (93.1mm bore) and which will be lug-centric (anything larger) in the way they attach and center onto the hub. If you're not familiar with those terms, don't worry, it won't affect fitment or function, either mounting method works fine.
  • PART NUMBERS are included so you may inquire directly with your favorite Authorized ICON Dealer with a specific part number in hand when checking price and availability.
  • This list includes ICON's 17" wheels only, at this time. I will update it soon with 18" and 20" Bronco-compatible part numbers.
REBOUND PRO 17 X 8.5
With patented InnerLock Bead Retention Technology - More Info in This Thread
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels REBOUND-PRO-on-Bronco
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-REBOUND-PRO
FINISHBACKSPACEOFFSETHUB BORELOAD RATINGPART #
SAT BLACK4.75"0mm106.1mm3200 LBS21817858347SB
BRONZE4.75"0mm106.1mm3200 LBS21817858347BR
TITANIUM4.75"0mm106.1mm3200 LBS21817858347TT
SAT BLACK5.75"25mm95.1mm3200 LBS21817859057SB
BRONZE5.75"25mm95.1mm3200 LBS21817859057BR
TITANIUM5.75"25mm95.1mm3200 LBS21817859057TT
REBOUND SLX 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-RBOUND-slx
SATIN BLACK4.75"0mm106.1mm3200 LBS1917858347SB
CHARCOAL4.75"0mm106.1mm3200 LBS1917858347CH
SATIN BLACK5.75"25mm95.1mm3200 LBS1917859057SB
CHARCOAL5.75"25mm95.1mm3200 LBS1917859057CH
REBOUND 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels REBOUND-on-Bronco
SAT BLACK4.75"0mm106.1mm2750 LBS1817858347SB
BRONZE4.75"0mm106.1mm2750 LBS1817858347BR
TITANIUM4.75"0mm106.1mm2750 LBS1817858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS1817858357SB
BRONZE5.75"25mm93.1mm2750 LBS1817858357BR
TITANIUM5.75"25mm93.1mm2750 LBS1817858357TT
COMPRESSION 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels COMPRESSION-on-Bronco
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-COMPRESSION
SAT BLACK4.75"0mm106.1mm2750 LBS2017858347SB
BRONZE4.75"0mm106.1mm2750 LBS2017858347BR
TITANIUM4.75"0mm106.1mm2750 LBS2017858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS2017858357SB
BRONZE5.75"25mm93.1mm2750 LBS2017858357BR
TITANIUM5.75"25mm93.1mm2750 LBS2017858357TT
VECTOR 6 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-VECTOR-6
SAT BLACK4.75"0mm106.1mm2750 LBS2417858347SB
BRONZE4.75"0mm106.1mm2750 LBS2417858347BR
TITANIUM4.75"0mm106.1mm2750 LBS2417858347TT
SAT BLACK5.75"25mm93.1mm2750 LBS2417858357SB
BRONZE5.75"25mm93.1mm2750 LBS2417858357BR
TITANIUM5.75"25mm93.1mm2750 LBS2417858357TT
ALPHA 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-ALPHA
SAT BLACK4.75"0mm106.1mm2500 LBS1217858347SB
GUN METAL4.75"0mm106.1mm2500 LBS1217858347GM
BRONZE4.75"0mm106.1mm2500 LBS1217858347BR
TITANIUM4.75"0mm106.1mm2500 LBS1217858347TT
SAT BLK/MACHINED4.75"0mm106.1mm2500 LBS1217858347MB
SIX SPEED 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels SIX-SPEED-on-Bronco
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-SIX-SPEED
SAT BLACK4.75"0mm108mm2500 LBS1417858347SB
GUN METAL4.75"0mm108mm2500 LBS1417858347GM
BRONZE4.75"0mm108mm2500 LBS1417858347BR
TITANIUM4.75"0mm108mm2500 LBS1417858347TT
SAT BLK/MACH4.75"0mm108mm2500 LBS1417858347MB
SAT BLACK5.75"25mm108.1mm2500 LBS1417858357SB
BRONZE5.75"25mm108.1mm2500 LBS1417858357BR
TITANIUM5.75"25mm108.1mm2500 LBS1417858357TT
THRUST 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-THRUST
SAT BLACK4.75"0mm106.1mm2750 LBS2817858347SB
SMK SAT BLACK4.75"0mm106.1mm2750 LBS2817858347SSBT
SAT BLACK5.75"25mm93.1mm3200 LBS2817858357SB
SMK SAT BLACK5.75"25mm93.1mm3200 LBS2817858357SSBT
COMPASS 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-COMPASS
SAT BLACK4.75"0mm106.1mm2750 LBS3217858347SB
SAT BRASS4.75"0mm106.1mm2750 LBS3217858347BS
RAIDER 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-RAIDER
SAT BLACK4.75"0mm106.1mm2750 LBS3417858347SB
SAT BRASS4.75"0mm106.1mm2750 LBS3417858347BS
TITANIUM4.75"0mm106.1mm2750 LBS3417858347TT
VICTORY 17 X 8.5
Ford Bronco ICON Alloys - Current List of Bronco Compatible Wheels Colors-VICTORY
SMK SAT BLACK4.75"0mm106.1mm2750 LBS3017858347SBT
SAT BLACK RED4.75"0mm106.1mm2750 LBS3017858347SBRT
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I like the Vecotrs and the Thrust. Very nice!
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
wanna1
Andrew
2013 Ford F150 Platinum 4x4 2022 Mach E
Beadlocks ?
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
Beadlocks ?
The Rebound Pro at the top of the post features our InnerLock bead retention technology. We do not sell a wheel with a separate beadlock ring.
wanna1
Andrew
Thanks !!!
dweskamp
Dan
Missouri
2016 GMC truck
REBOUND 17 X 8.5
VECTOR 6 17 X 8.5
ALPHA 17 X 8.5
SIX SPEED 17 X 8.5
THRUST 17 X 8.5
COMPASS 17 X 8.5
RAIDER 17 X 8.5
VICTORY 17 X 8.5
Need a Thrust in Bronze
HudsonAlex
Alex
Anaheim, CA
Ford Fusion, 39 Hudson coupe
When I ran the compatability fit on your website it says these wheels 2817858357SSBT won't fit. Is that correct or did I do something wrong?
WarDamnBravos
Newport Beach
2018 Wrangler
Can you drop in as many pictures as possible of the wheels on actual cars? I have a hard time picturing what they will look like just looking at the wheel
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
That's because I'm quicker than our web guys LOL...nah that's just a mistake. I've let them know, they should be updating it soon. In the meantime, you can probably trust my list above more than the website :)
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
I start adding the few that I have, of the wheels on Broncos, to this thread. But I only have them on Broncos for a couple of the wheel styles. I'd hate to litter the Bronco forum with a bunch of Jeep and Toyota pics LOL.
