30 Amp Aux switch - uses?
Ru4Scuba
Toyota Minivan
All
Curious what (if any) non - lighting uses you have for your #1 30 Amp Aux switch? Most of the lights etc I’m seeing could get by with switches 3-6. I is rated for 30 Amp and 2 is rate for 15 Amp.
What are some uses you guys have for these heavier current switches?
a94cobra
TX
2022 Bronco
How many amps a winch pull? I thinking it could be over 30.
Bud2020
FL
Badsquatch 2.7 Lux
You could wire a relay shut off to an aux…that’s what I have going on 6.
Ru4Scuba
Ru4Scuba
Toyota Minivan
what relay are you shutting off with your six switch?
Bud2020
FL
Badsquatch 2.7 Lux
Ru4Scuba
Ru4Scuba
Toyota Minivan
Ok…dumb question for this electrical noob.
what does a warn power do and why would you need it? If you were maxing the load on your battery?
Tilzbow
NV
GM Sierra Diesel Pick Up
It simply shuts off the power to the winch so it won’t operate. I’ve heard some do this to prevent the winch from unspooling on its own but I think the possibility of that happening is extremely low. Some might be paranoid that someone will operate their winch while they‘re away from their vehicle but again that’s unlikely since you need the winch controls plugged in and those are generally kept separate and in the vehicle. Maybe some are worried about the winch drawing power even when it’s not being used and draining the battery. I personally can’t see a reason to add a power cutoff to the winch but there are different strokes for different folks…..
JKommuter
F250, Escape
In an accident not having live 2 gauge wire on the bumper is a good thing.
Ru4Scuba
Ru4Scuba
Toyota Minivan
Aha…starting to become more clear now…thx for all the responses!
Squatch Parade
Mickey
Montreal
2021 FE
to make aux 1 more complicated, not only do most lights not need 30 amps, but the wire itself seems to be 1.5mm2 thick, which at most should only push 15-20 amps.. maybe it was designed for a fridge or something with spike wattage?
Ground_zero298
Scs michigan
Power to the winch relay is good to have toggled. Seen more that a few rip bumpers off side by sides and/or rip the hook off or lock the line up.
Ru4Scuba
Ru4Scuba
Toyota Minivan
maybe the OEM fridge they are pushing?
