JL8jeff
Ewing, NJ
Good video. Can you reinstall the shutters (on a base model) with the CVF intercooler if you wanted to?
Bellime
Keith
2022 Ford Bronco
Nice work up, I wish I had captured a before upgrade set of numbers, but the seat of pants metric has been great.
About 1-1/2 years ago I did the Whipple IC, then I did the AFe Hot and Cold charge pipes and finished with the Ford Performance Tune ProCal. I need to learn how to connect the ProCal and capture the numbers to see where is am at now, but won’t be able to see the before side.
I did the exact same thing with the shutter assembly and I have been in negative temps in Montana with no problem.
I love your video, please do more, especially about the ProCal stuff.
thanks again for sharing.
MWILD
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
Much appreciated and plenty of videos coming soon. Trying to dig deeper in the ProCal, but still need to do more research. I’ll probably end up switching over when custom tuning becomes available.
Hkak45
K
Illinois
21 Bronco Black Diamond
How are you liking the Whipple IC after the time you had with it?
Bellime
Keith
2022 Ford Bronco
35k miles through some tough winter conditions and now 118 desert stuff, still churning
nolimits
23 Badlands
After running this awhile have you seen any negative effects?
Any issues in rain/wet conditions? Particularly any water crossings you may do? I’m not sure all the intricacies on the shutter system but thought it may have a moisture sensor to close up in wet conditions.
lat2801
NM
2024 Bronco
the shutter system is just there to properly cool and warm up your temps depending on the weather. Shutters close when it's cold outside to warm up the engine quicker
nolimits
23 Badlands
Thank you for confirming this, much appreciated.
CarGuy
New Jersey
2023 Ford Bronco
My understanding is the shutters are used for fuel economy - e.g., eco mode. They shut to create better aerodynamics.
Ducati1098
It may help with that a very small amount, but its main purpose is to manage charge air temps.
Travis9935
Travis
2024 Bronco sasquatch
Why do all tabloids say ford added them for mpgs then? I personally take them off because it makes a pretty drastic difference while towing in the summer. And I've never even noticed a dif on mpgs. Temps def run alot lower with them unplugged while open or removed.
Ducati1098
Well there are 2 different shutters, so they may be talking about the other ones.
The larger radiator shutters are more so for MPG and also help with getting the vehicle up to temperature quicker.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Great video! Thanks for sharing with the forum.
For those interested we have an exclusive sale with CVFAB going on till the end of the month on all of their products. Whether it be an intercooler, catback or downpipes it's all on sale. Just head on over to the site and place your order. No codes needed and don't forget about our Team Lethal F150 giveaway.
https://www.lethalperformance.com/
Feel free to give us a call if you have any questions.
Thanks!
