Riggs83
Milwaukie Oregon
2023 4-door Wildtrak, 2023 2-door Wildtrak
I wanted to share a few details about installing a CB Radio. Yes, up here in the Pacific Northwest CB radios are still popular especially with log truck drivers. I'm not going to get into specifics about setting up the CB. Except to say, follow the best practices about installation and grounding. Right Channel Radios has some great information about that. I use a short antenna with a spring and that gives me good SWR readings.
I fabricated a transceiver mount out of 12ga aluminum plate I got at the scrap metal yard for about $7.00. I mounted that over some rubber and nylon washers to clear the firewall insulation at the clutch pedal mount on the firewall just above the foot rest. It's more solid than I expected. Make sure your transceiver is mounted high enough so your cable doesn't run into the interior panel to the left. I ran power directly to the battery.
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_094628
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_103414
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_103350
Ford Bronco Cobra 75 All Road CB Radio Install 20240519_142021
I used a Mountains to Metal Flag/Antenna Mount Bracket and it worked out very well. The hole in the bracket is large so I had to use a washer between the bracket and the first nylon bushing in the antenna stud. I had to sand off the powder coat around the bottom of the antenna hole and one side of the grounding hole to get the antenna grounded to the chassis. I used the grounding location just above the subwoofer. By the way, you can remove the interior panel without removing the floor board in the cargo area.
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_144210
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_163252
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_163311
Ford Bronco Cobra 75 All Road CB Radio Install 20240518_150715
Ford Bronco Cobra 75 All Road CB Radio Install 20240519_105324
I had to use a 35' RG8x Coax cable to make it long enough to reach with some left over that I tucked in to the right of the subwoofer. 18' cable is not long enough to reach in this configuration. I had to run the ground and the coax through the door vent. I really wanted to use the grommet for the center brake light but the coax end is way too big. I may change this in the future but it seems OK for now. I made sure I had a weather loop before going into the vent so water would not follow the cables into the door.
Ford Bronco Cobra 75 All Road CB Radio Install 20240519_170849
I selected the Cobra 75 All Road for the wireless feature because I didn't want to have the radio show when I wasn't using it. It just plugs into the USB port on the dash for a really clean install. The 75 All Road mic has a smaller than normal stud on the back. So none of the after market mic holders from Bulletpoint or Tackform really worked that well. So I made my own mount for the mic using parts from Tackform and some nut caps.
Ford Bronco Cobra 75 All Road CB Radio Install 20240524_195854
Ford Bronco Cobra 75 All Road CB Radio Install 20240525_102030
Ford Bronco Cobra 75 All Road CB Radio Install 20240525_154456
Here is my view when the radio is in use and what the antenna looks like from the rear. I used a Firestick II, 2' and ordered a black tip. I wasn't really fond of the red tip that came with it. I'm getting well under 1.5 SWR readings.
Ford Bronco Cobra 75 All Road CB Radio Install 20240525_150717
Ford Bronco Cobra 75 All Road CB Radio Install 20240525_150804
Ford Bronco Cobra 75 All Road CB Radio Install 20240601_081215
Hope this helps. Reach out if you have any questions.
Magnitude Flow
Pete
Washington
FJ Cruiser
I'm out of Snoqualmie, was thinking about something similar.
AXMRDR
Central Arkansas
'22 Bronco, '02 F350 4WD Crew, couple of Harleys
This model CB is the next one I plan to buy. Great for using on motorcycles as well.
Nice install.
beetle
SoCal
2022 Bronco
I might "copy that".
Bellime
Keith
2022 Ford Bronco
On my wish list, just need to figure out how to install side by side with my GMRS radio
Riggs83
Riggs83
Milwaukie Oregon
If you figure it out let me know, I think that will be my next project. I think the antenna for that is going up front. I read somewhere the antennas should be at least 12" apart.
Bellime
Keith
2022 Ford Bronco
True, but I doubt I will use both at the same time.
Bellime
Keith
2022 Ford Bronco
Oh, I just thought, maybe have the other antenna on the other side of the spare tire. The bracket will be tougher to design
Riggs83
Riggs83
Milwaukie Oregon
Mountains to Metal makes the bracket in a left or right side configuration.
Chapito
Laredo, TX
2023 Bronco Wildtrak
This might be a stupid question but what are you grounding on the antenna mount? I'm looking to buy a CB and antenna but have not decided which antenna to go with yet. I'm thinking of going with the President Ronald Compact 50 Watt. Which antenna and mount did you go with?
Riggs83
Riggs83
Milwaukie Oregon
That's not a stupid question. A CB antenna mount needs to be grounded to your vehicle's chassis with a really good ground. The CB antenna needs a good ground for transmitting and to obtain a good SWR level. Go to Elements of a Successful CB Installation | Right Channel Radios to learn more. Get a SWR meter, and a tunable antenna is helpful. I used a FireStik II antenna and a Tailgate Flag Antenna Mount Bracket V2 (PASSENGER) - Bronco 6G 2021+ - Mountains2Metal passenger side. The lenth of your cable makes a difference also, so look for that information too. 18' is recommended, but that was not long enough for my installation. I used a 35' to make it work.
Hope this helps.
mwdsonny
SC
2021 BL bronco 4 door Cyber Orange (School Bus Yellow)
I see you used a 35' cable you didnt mention how much you had left. would a 25' have worked? also interested in selling a bracket?
Riggs83
Riggs83
Milwaukie Oregon
I used a 35' cable because CB cables work better in 18' increments from my understanding. There is a performance consideration when determining the length. But I don't remember if I had 10' left over, It was close.
As far as the bracket, I would have to remove the whole thing to make a template. I have so many things on my list, I don't really have the time. Sorry about that.
mwdsonny
SC
All good thank you. I'm debating where I want to install still
