a new estimate of the bronco 4-door wheelbase
BE_
BE_
1996 jeep cherokee, piece of junk Korean car
thats why its a calibration. you measure based on the front and rear tires and split the difference.
I don't think that's very complicated.
indio22
Chicagoland, USA
Also, consider if a photo is taken with a wider angle lens, it could cause the object to appear longer. Reason being as the object gets further to the edges of the photo, the object appears to stretch. To be precise, I think both photos being compared, should be taken with the same lens magnification.
(Edit: I guess you could identify/correct for the situation I mentioned, by measuring the height of the tire, compared to the width. If both of those measures do not match, then you will know the object is experiencing some "stretch" due to lens distortion.)
BE_
BE_
ok, I have gone back and did several measurements in several ways on several of the spyshots and have gotten the following results fairly consistently:
wheelbase: 114 inches
legnth: 14 feet
take this as you will.
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
can you check for overall length without bumpers?
WB = 3.25 tires (34.4*3.25) 112”
length (less the bumpers) 4.75 tires (34.4*4.75) 164” or 13.7’ so 14ft or so
FirstOnRaceDay
Devin
Toledo Ohio
2 door I got about 98” WB and 12.5’ long
  • Like
Reactions: BE_
BE_
BE_
Paint
Jack
Oklahoma
Tundra
Using 34.7 for the tires, I came up with 174 overall (bumper to bumper) and 115 for center cap to center cap.
Not sure why I used 34.7 though...I aint going back and redoing that math haha. It's in line with what y'all posted.
But yeah...No way is this 16 feet long. The only way this truck has 16' long bodywork is if those tires are over 37" tall.
Paint
Jack
Oklahoma
Tundra
How is a 4dr Bronco going to be shorter than an FJ.. Google says the FJ is 184"...
Dunno...But JLU is 188 (pretty sure that includes the spare, which we're not including here).
BroncoRevital
Zak
Toyota Tacoma, past; 94 FB, 86 FB, 84 Bronco2
I still want a 2 door but I'm hoping the 4 door is 112". That seems like a perfect size to me and might even persuade me to get 4 door.
Camel
T x s
Bronco II
If my 2 cents are worth anything (I know they aren't) this seems the most logical.
Same. Either way, I'll be happy.
4 door if the wb is 112.
If it's 124, then the 2 door will be about 108ish which even better!
Paint
Jack
Oklahoma
Tundra
At least we know it knows how to party in the sun.
