Why didn't Ford give the 2 Door and 4 Door Bronco the same wheelbase?
Status
Not open for further replies.
R.A.N.M.J.
Rick
So, I've been in and out of quite a few Broncos over the last few months and one thing I keep thinking whenever I see the 4 Door model: Why didn't Ford just both configurations on the same wheelbase?
Purely speculation on my part, but I think the designers got so dug in with the whole "Wrangler Killer" mentality that they missed the obvious engineering advantages.
The 4 Door Bronco isn't much bigger than the Bronco overall and really isn't that big in a grander scheme when compared to other brands in similar markets.
Ford could have extended the cargo space on the Bronco and just retooled the body panels to accommodate both configurations. This would have also made it far easier to convert the Bronco into a truck with a bed and no back seats or into a hybrid down the line with the extra space afforded the undercarriage.
Not to mention roofs would be a simple issue. One size fits all, sorta thing.
I guess they needed something a bit smaller and nimble looking to compete directly the Wrangler market. Still, I can't help but wonder...
In all fairness, having driven both, I prefer the off-road driving capabilities of the 4 Door configuration but the styling of shorter wheelbase Bronco appeals to me far more.
Tricky Dick
Dick
PNW
87 Suzuki Samurai, 03 Ford F250
I like the subtle jab.
They probably had a wheelbase target in mind and built to that. Works for me, I wouldn't want a 2dr as long as the 4dr. Now if it was flipped the other way, the 4dr on the 2dr frame, I'd be a lot more accepting of the 4dr. It wouldn't be nearly so ugly. Shared wheelbases worked for the XJ Cherokee.
R.A.N.M.J.
R.A.N.M.J.
Rick
They need the shorter wheelbase to generated the break over angle that beats the Wrangler.
Yeah, that's kinda what I was getting at. But, at what cost? Yanno...
Laminar
Iowa
Cougar
They need the shorter wheelbase to generate the break over angle that beats the Wrangler. Marketing decision is my opinion.
The entire existence of the Bronco is a marketing decision. Breakover angle has real world offroad benefits, as does a shorter wheelbase overall. So breakover performance is as much a "marketing" decision as was 35" tires or a good stereo or cool LED headlights or anything else that would make someone want to buy a Bronco.
Per the bajillion 4 door vs. 2 door threads here, some people reeeally like the proportions of the 2 door, and those proportions would be different on a different wheelbase.
What OP is asking for is more like the LJ Wrangler - a stretched 2 door body on a 4 door frame.
People don't want the two door because it only has two doors, people want the two door because they like the size and shape and look and function.
NC_Pinz
Central NC
This thread doesn't make a lot of sense. It is like the OP thinks the 2 door was an afterthought or was developed after the 4 door. The 2 door is based on the early Bronco. It matches up within inches of the original. The 4 door was developed to provide 4 doors. The two using the same wheelbase doesn't make any sense.
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
What?
The 2021 with 2 doors is much bigger in all dimensions compared to an EB. Just in length it's over 20 inches longer.
R.A.N.M.J.
R.A.N.M.J.
Rick
The Bronco is an acceptable size. The 2 door Bronco is tiny, they should of built it on the Bronco frame.
Internally the 2 Door configuration is referred to simply as "Bronco", the 4 door configuration is referred to as the "4 Door Bronco". ĀÆ\_(惄)_/ĀÆ
I stand corrected! And correct I stand!
Projecting much? It's not arbitrary, it's a simple observation I made. I wanted to talk about it. I could give two shits about what other people choose for themselves.
It would have just made more sense to me from a manufacturing standpoint for them to roll out both configurations on the same wheelbase.
edgeflyer
2013 FX4
The existence of the 2 door is the only reason the 6G Bronco can retain the retro Bronco credibility. I don't dislike the 4 door, but without the 2 doors running around, the Bronco brand would not have the emotional attachment as it does now. In my opinion, it works in the 4 door favor if they cant live with a 2 door daily.
Moabbob
Bob
Kansas
2020 Toyota Land Cruiser, 2018 VW Golf R
The 4 door has a wheelbase that’s 4 inches longer than my 200 series Land Cruiser. The issue is break over when off road.
Spooled
Republic of Texas
2017 F-150, 2021 ZR2
Meh. Instead of neutering the Bronco's capabilities by throwing it on the 4-Door Bronco frame we could have just not had the 4-Door altogether IMO. That's a much more controversial opinion 😬
That would have been my preferred method of production streamlining.
Vantcrst
CA
92 Ford F-150, Mercedes 4x4 Sprinter Van,
You can see from the responses to your post what the answer is. The shorter wheel base 2dr and longer wheelbase 4dr appeal to two different customer bases. Like most, I think the 2dr looks way cooler but in order to justify buying one I need the practicality of the 4door. I don’t think there would have been a ā€œGoldilocksā€ wheelbase length that could have satisfied both groups. Would have been great from Ford’s perspective but in the end I think they will seek more vehicles giving folks the option.
BossMann
Louisville
2009 Honda Pilot
approach/departure/breakover angles would have been horrible.... No way the same wheelbase would work.
Status
