Adding Sound Insulation for 4 Dr. Hardtop?
Bronco2023srb
Charleston SC
2023 Bronco 4 Dr.
I’m preparing to make a trip from SC to MT in my 4Dr. Bronco. I added a Yakima lock-n-load platform to my factory roof rack plus pelican cases for added storage. The increase in wind noise is pretty significant so I’m asking the group if anyone has added aftermarket sound insulation to their 4 door Bronco? If so did it help, and what brand. Pictures would be helpful.
Thanks
Ford Bronco Adding Sound Insulation for 4 Dr. Hardtop? IMG_3398
Ford Bronco Adding Sound Insulation for 4 Dr. Hardtop? IMG_3391
Ford Bronco Adding Sound Insulation for 4 Dr. Hardtop? IMG_3387
dadjoke
Southern California
'22 Bronco Big Bend 4-Door 2.7 MIC Auto Sasquatch
WheresMyBronco
Los Angeles
2023 Badlands
Alassise
Al
Thanks
I used Killmat on my soft top for only the floor. Doors will be later. Now, this will help you a bit, but for the noise that you are describing I don’t think it will help at all, as it is cause by wind drag.
2Jeeps&PatriotX1
Denver, CO
I need to get that slide out and install for that exact same purpose. Loading up the dogs into their Ruffland kennels. I installed the Hot Head headliner w/ the sound assassin option but unfortunately, not sure if it'll help in your case or not since the wife's Bronco doesn't have a rack or anything on top.
MNBigfoot
MN
Hot glue gun and an egg-crate foam mattress pad, it should look a little cleaner than the Anderson HT headliner.
BoverW
J
Socal
Try this first.
