Aftermarket Hitch - which install without removing the bumper
AZ_Liberty
2007 Expedition
So, which aftermarket hitches install with the bolts inserted from the front of the vehicle so you don't have to remove the bumper?
Looks like the Curt might be able to installed from either direction?
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
Installed my Curt without removing the bumper.
HoosierDaddy
Indiana
I installed the Curt as you described.
I saw another post where the guy bought new bolts that were 1/2 an inch shorter, probably not a bad idea, the ones they sent damn near still make contact coming out the other side.
MacsOBX
Mac
Mineral, Va
Toyota Sequoia
With the bumper on, the bolts can only go on front to rear. I had to shorten the bolts that came with the CURT hitch to make it fit correctly.
EveryDayBronco
Motorcycle
They're pretty much all the same, just insert the bolts from the front.
Lifeliberty
Moonbeam👀
Columbus, OH
My curt fit fine with no mods or bumper removal
Did need to start at angle inserting bolts. Don't tighten things until all bolts in.
Ford Bronco Aftermarket Hitch - which install without removing the bumper 1656794214101
dan79
dan
ma
08 f250
I did the Rough country one same way bolts pointing to the rear
dan79
dan
ma
08 f250
wait I thought of something better lift it with 3 inch body lift and bumper relocation brackets from broncbuster then u can put the bolts in the right way. That is a perfect excuse for the wife that it had to be done lol
KABQ
Aaron
Albuquerque, NM
Installed Rough Country hitch this weekend, and the bolts can go either way. I wanted the bolts to go back to front so I removed the bumper. It was incredibly easy to remove (eight 15mm bolts and one wire connector) and the extra room made it way easier to torque (280 lb/ft!!!). Realignment was a no-brainer.
If you do remove the bumper, you do not need to remove the 13mm bolts (oops).
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I have the curt with the Ford Metal Bumper. I installed it without removing. It’s not hard. No cutting for me.
Wark
Kurt
Syracuse, NY
'22 Ford Bronco
I just received the Curt 51062 class III hitch for my birthday, which is now beyond the return period, happy to see a fellow base owner had successfully installed with removing bumper.
Donkeygyrl
Sheri
San Francisco
Bronco on order
20 minute job ,use magnet on wand install with nuts facing forward.
Hdscreens
Will
2dr Bronco Badlands
Which wiring harness has proven to be easy and reliable to
instal?
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
