Draw-tite 4500/675lb hitch install without removing bumper
illverado
Cory
700whp stick shift 2000 silverado 2011 caprice ppv
So, I got this draw-tite hitch receiver for my 2 door base manual sasquatch (since the tow package isn’t an option on these) from towuniverse.com on sale for $109. Draw-tite and Reese are owned by the same company, this is the shorter normal length version PN: 76605-1. The reason I chose this one over others that are readily in stock everywhere else is because of the certified weight ratings of 4500lbs max gross and 675lbs max tongue. Obviously our broncos aren’t rated for that much, only the raptor, but I still think that’s a good indicator that this is the highest quality and value hitch on the market especially at $109. Good luck finding it in stock or the Reese equivalent PN: 84605 anywhere but I got lucky! It looks nice, thicker receiver hole doubling ring than others and the material appears thicker than all the other brands.
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper E525F1F7-3CE2-4A2A-90D3-91907D5A63A0
So now here’s my install walk through:
Step 1: put the included grade 5, 1/2”-13 4.5” long bolts in your spare bolts bin
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper 0B55A892-958A-4F28-AD03-1A3E514B40CC
Step 2: get shorter grade-8, 1/2-13 4” long bolts instead
Step 3: bolt the hitch on putting the bolts with washers in from the front and use a 3/4” high angle wrench to hold the nuts, tighten and torque the bolt heads and done!
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper E404CE09-C15E-48DC-AB55-3EDF395B53E9
As an airplane mechanic one of the general rules we follow is always install bolt heads in the direction of flight, so if a nut does happen to fall off, at least the bolt will tend to stay in place. Another rule is you need at least 2 exposed threads showing past a nut with a locking feature like the ones included. Well there’s plenty of room to get the bolts in the correct direction and still get a torque wrench and have 2+ exposed threads sticking out of the nut once tight sooo why take the bumper off?!
turns it into the easiest 1 person job ever. Hope this helps someone!
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper 9D9E6DD8-083C-4CBD-BFFE-B558C27F5E5D
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper 90DD0C3A-1390-451C-A1A0-0325281E9BF2
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper 7D4259EE-A03C-4849-9B82-2A680965E811
BigFootie
Wisconsin
Just ordered mine now. Thanks for sharing!
BigFootie
Wisconsin
Looks a lot easier than my Escape. Holding up a 30lb hitch while fishing a wire attached to a bolt through the vehicle frame wasn’t that much fun the first time but had to do it again a second time after the first one rotted off after 15 years.
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper A9516B8C-1726-4CEB-8138-03CBCA4AA1F3
HBTFD
Newnan GA
F350
Another tip for the middle 2 bolts, make sure the muffler is cold. You can move the muffler to get a better angle on the bolts. You don’t want to touch the muffler if you’ve been driving for 20 minutes.
BroncoEnvy
Jonathan
2022 Bronco Badlands 2dr, 2006 F250 FX4
@illverado What is the distance between the holes on the plug mount? I am looking at purchasing the same Draw-Tite hitch and was hoping to mount this 7/4 Pin Plug on the bracket that comes on the Draw-Tite Hitch. The 2 screw holes on the top are dimensioned at 2 3/8" apart per the etrailer website. It looks like it should work, but would be nice to know what the hole spacing is on the hitch first. I tried asking etrailer but they haven't responded in the last week, so hoping you might be able to help me out. Any help would be appreciated :)
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper Hopkins Plu
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper Hopkins Bracket
illverado
illverado
Cory
I’ll measure on my lunch break
Techun
Pa
BD, 2.7, MIC, 4dr
My regular-ass drawtite hitch could use the stock bolts. You just go in at a slight angle.
illverado
illverado
Cory
BroncoEnvy
Jonathan
Sorry I forgot! Whole bracket is 2-1/2” wide, bolt hole options are 2-1/4” or 1-3/4” spacing
Ford Bronco Draw-tite 4500/675lb hitch install without removing bumper 6CB20682-E85B-4F90-929A-A82C4DC73BBD
Awesome! I really appreciate it, thank you!
Macclone
Iowa
2020 F250 Super Duty Platinum diesel.
Got a Curt installed for $158. With 4 pin wiring, I was all in at $570.
illverado
illverado
Cory
Nice, but that hitch is only rated for 350lbs tongue/3500lbs
