Draw-tite 4500/675lb hitch install without removing bumper
lapazleo
Indiana
2022 bronco badlands
I've put hitches on two 6g's no need to remove bumper steel or plastic. Just a little patience.
illverado
illverado
Cory
700whp stick shift 2000 silverado 2011 caprice ppv
So is the Bronco perfect match.
Can get away with more relatively safely with a weight distributing hitch imo. Long boat trailer or my 4100lb truck on a tow dolly at conservative speeds. Might be zero difference before the hitch or frame crossmember fails but at least my hitch is certified for it. Might try it some day or might never tow anything 🤷‍♂️
anomdeplume
Tampa, Florida
2023 Bronco, 2023 Bronco Sport
Thank you for the write up and photos. I ordered my Draw-Tite 76605 through a Walmart link.
https://www.walmart.com/ip/Draw-Tite-76605/2809034149?wmlspartner=wlpa&selectedSellerId=101409059
This Walmart option did NOT come with hardware so you’ll need to buy your own. Picked up some 4” long grade 8 bolts as OP recommended. The clearance is tight but plenty of thread when you get down to the torque step. I can see where 4 1/2” bolts might make it so you need to remove the bumper. With the 4” you don’t need to remove the bumper.
da_jokker
Jeep Wrangler JKUR
Can't you order the Factory hitch cheaper? Maybe use some points and get it for free.
Besides...the hitch isn't the issue.. it's that weaker frame bar it's bolted to.
You want a strong hitch, you need one that mounts to the outside frame railing.
