Aftermarket manual transmission swap into the 2.7 ?
huev05
Timothy
Tampa
Jeep wrangler
would it be possible to swap the transmission in the 2.7 out for an aftermarket manual transmission? Has anyone attempted this?
E. Davis
Charlotte, NC
2019 Mustang GT Velocity Blue
The key word here is "possible".
It is possible to send a manned mission to Mars, the big variable is cost. There is no easy bolt-on MT swap for the 2.7. It would take a completely custom endeavor, including a galactic challenge of programming for all the computer systems that talk to the transmission.
Possible? Probably
Worth the $$$? Probably not, unless you have SEMA build money or greater.
sgraing1
451xx
2022 Bronco Black Diamond.A Bunch More Junk.
You would be better off cranking up the horsepower and torque on the 2.3 engine.
RagnarKon
Ford Bronco, Escape, Focus
Possible for sure, but as @E. Davis mentioned... not economical.
The 2.3L EcoBoost has been paired with the MT82 transmission in the Ford Mustang for years, as well as the Focus, Ranger, and Everest Ford sells overseas. The MT88 transmission in the Bronco is similar to the MT82, and likely why Ford was able to add the manual trans to the Bronco.
Ford has never paired a manual transmission with the 2.7L EcoBoost before, so there isn't really a factory configuration to base it off of. You can do it for sure, but you'll have to do all of the work yourself—there is no blueprint for it.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Everything's possible with a lot of money.....even a Coyote.
It would be an interesting development for sure.
