Alternate Fog Pocket Solution Installed
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
Nope, I bought the harness with the bracket. I just tied the third connection out of the way.
Do you happen to recall which one you used?? Thank you.
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
  • Like
Reactions: JAC
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
@Bigmoose Quick question for you; did you happen to make your own wiring harness or did you purchase one from @4x4TruckLEDs.com? I didn't see that in your post. If you wired on your own; did you have any issues? IF you purchased then which one did you receive?
@4x4TruckLEDs.com I may have to reach out as I know I didn't order a wiring harnes.
Thanks all - Hope you all had a Merry Christmas/Happy holiday
You can grab a harness here: https://www.4x4truckleds.com/installation-accessories/switches-harnesses/
  • Like
Reactions: JAC
dcaero
Bronco OBX SAS
Thanks for posting this idea, as I copied it! Just arrived today, can't wait to get them installed.
Ford Bronco Alternate Fog Pocket Solution Installed IMG_20220106_122033
patch1103
P.
Chicagoland
2017 JKU 75th Anniv. Edition
Looks great!
I went with the above lens combination. I like the look and functionality, and the lenses are cheap if I want to change them up. I'm ordering the factory light switch with both front and rear fog light buttons, so will use that for the SAE ambers and will utilize two of the upfitters for the S2 Pro's.
That looks great! Man, I'm really torn here. I was pretty much sold on the Dynamic Diode kit because of the power output and nice clean cutoff, but the fit in the bumper pocket doesn't look as clean as the Baja Designs. Choices, choices...
patch1103
P.
Chicagoland
Back lighting is personal preference. You don't need it. If you go with SSC2 pods you could just not connect the backlights.
Maybe this is a stupid question, but what's meant by "backlighting"?
Bigmoose
Bigmoose
Jon
RI
JAC
Joshua
Oregon
does anyone have pictures of with/without fog lights at night?
I should thursday night. Will be installing mine that day and will post up here.
Bigmoose
Bigmoose
Jon
RI
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Djd7
Northeast
BD
@Bigmoose did you end up using the 2nd, middle channel on the brackets?
Ford Bronco Alternate Fog Pocket Solution Installed Screen Shot 2022-01-12 at 4.09.03 PM
