- John
- Oct 23, 2020
- 3
- 684
- 1,156
- Stafford VA
- Badlands 2.3/Manual and a Gaggle of Jeeps
- Badlands
So I haven't gone deep into it yet, But I'm trying to figure out if I can upgrade the alternator in my Badlands 2.3 M/T.
Ford shows 2 Alternators for it, but no real specs on them;
MB3Z-10346-H For the 2.3l Without Power Inverter,
MB3Z-10346-A For the 2.3' With Power Inverter
I'm assuming the second is the more powerful alternator, Since the 400 Watt inverter could draw almost 40 Amps at full load. But the only spec I can find is 240A for the "Standard" alternator.
I think I'm hitting the edge (Or Exceeding) what my standard alternator can handle. I've had 2 Audio Amps, (a 300 watt 4ch and a 500 watt Monoblock) in the Bronco for a while, and just put in a Hoss 3.0 Steering Rack a couple weeks ago.
Now as soon as I start the Bronco it will go to 14.6v on the voltmeter almost immediately, and usually go up from there, Occasionally exceeding the 15.2v expected Top end. I got a "check charging system" message when it hit 15.3 on the way home from work today, But it cleared itself in a few minutes and dropped down to 14.6. Thus far the battery is holding about 12.4~6 Volts when the engine isn't running, so I don't think it's cooked, and I don't think the regulator is shot, or I'd get even crazier readings.
I'm going to check it over in depth tomorrow, Disconnect the Amps, and see if I can see anything in particular that seems to be making huge draws.
What I was hoping, though it's a small hope, is if anyone knows what the difference is between the two alternators, if they are interchangeable, and if the bus will even know how to handle the other alternator is it is better. I haven't heard of anyone trying to make this swap yet, so I won't be surprised if no one knows, But I have to ask!
