Is my alternator killing my battery?
Ducati1098
I’m thinking this may be my issue (SSM 52258) I tried operating the door lock switches and the drivers side did seem to have a bit of an issue a couple times when I hit the bottom button it didn’t work but it did start working the next time I pressed it, it continued to work after that for a while then it happened again, also the drivers side window is no longer dropping when the handle is pulled (no drop and raise when door is closed), I did try a window reset to no avail. Time to drop it off….😒
Well hopefully they get it figured out for you
