Amazon vs. Ford Emblems - 24 Ford Bronco
PatH
Pat
St. Charles, MO
2022 Ford Exepedition
MY24 Ford Bronco is scheduled to be produced in January. Looking to get the cursive Bronco lettering, Black Bronco Rear Emblem, and Black Ford Logo Emblem (rear tailgate).
I see that they are available through Ford, and I also see them on Amazon. Is there any major differences?
Ford is a little more expensive, but looking for quality over price. Any information is appreciated or recommended products.
Thanks
Lowcountry Bronco
William
South Carolina Lowcountry
I bought 3 sets prior to my Bronco arriving,
1. Ford Performance ones that are on the Heritage Limited
2. Badgeslide ones (no longer on their site)
3. Archetype Racing ones
Honestly 1 and 2 are the same quality wise and are chrome plated metal with 3M tape but I went with my third option. Allot of the Amazon ones are plastic so look before you hit order unless that's what you're looking for, I'd just make sure they're Prime so you can return if you need to.
A lot of them on Amazon are unlicensed - they may not match exactly and the quality will vary wildly. But you might get lucky for cheap - part of playing roulette with chinesium parts
Wannabe Techie
Chicago
I bought Fordā€™s black gloss Bronco for tailgate. but then I went black matte and bought from Amazon. Works great. Amazon was returnable so I wanted to see it and Prime doesnā€™t cost for shipping. Low risk. I say try it because it isnā€™t that hard to make it.
Mr Bacon Jr
Gary
Santa Fe, NM
Bison ZR2
vbrad26
Vance
FL
VW's and now a Ford
If you end up with some Ford points, emblems are a good way to use them.
I bought my fender scripts from Amazon but both the black Bronco and Ford emblem I "bought" with points.
GroovyGeek
Boyan
'23 Bronco BD
I ordered an OEM Ford bucking bronco and frankly it is a disappointment. The gloss black looks cheap. Hopefully the plastic is higher quality, but if I had to do it all over again I would order matte black from Amazon and replace when/if it falls apart. If you decide to go OEM you may want to get M-1447-BRMB not M2DZ-7842528-B
For script emblems I went with this
https://www.amazon.com/dp/B09X356P9B
Metal, with 3M backing tape, very nice, at 1/3 the price.
I did buy the 3M primer wipes separately, probably no meaningful difference but they were something like $4/pad.
RBJRBJ
Bruce
2023 Bronco
Thanks
I purchased the Blacked Oval Ford emblem from Emblem City at Etsy ($163) in pic, vendor has a variety of emblems including Bronco script. I removed the blue Ford oval and installed matte/glossy black OEM replacement. Carefully removed the Ford Blue Oval, cleaned area with alcohol, peeled back the automotive tape, aligned the 2 push pins and inserted the new OEM emblem in place and gently heated it up with a hair dryer while pressing in place. Looks great. See pic
RBJRBJ
