Antenna Delete
Gen1&6
Adam
Cincinnati OH
1968 U15 & 2022 Badlands
Hey all - if any of you are like me, I dont listen to AM/FM radio at all. Always either listening to Spotify or SiriusXM. Therefore I do not need the factory antenna and the fact that it whips around all over the place & hits in some parking garages, I want to get rid of it. I have seen some “delete” kits that are in the $20 range that are a threaded screw with a plastic head on them, but figured I could use a simple “panel push retainer” in the threaded hole. Found the perfect diameter for the top as well as the length and thickness so it looks perfect. Figured I would share. I got this from Advanced Auto for $3.99.
Ford Bronco Antenna Delete 93A67BB1-2BE7-4D7F-997C-F6561451BA16
Ford Bronco Antenna Delete 9E11C6A0-30DF-4DD0-AE64-0F528F559B60
Ford Bronco Antenna Delete 49E98ACA-3081-4774-95D0-18FF94B64F26
BroncoAZ
Mitch
Good idea.
I used a stainless steel allen screw from the hardware store I hit with a black paint marker. I added a small neoprene washer to keep water out of the hole. I did end up buying one of the 3” Cravenspeed antennas for the $20 later because I wanted the ability to pick up some stations in an emergency (hurricane, etc.).
Ford Bronco Antenna Delete 705EEE72-4900-4BF5-AFB8-8A3BF02A8F5D
Ford Bronco Antenna Delete 39780C87-842A-41A2-AC3C-565542BB3F95
Ford Bronco Antenna Delete 0D0E0263-D3E7-4522-8479-F5447277E4DE
SPITmadFIRE
CA
I kinda like the stock antenna scraping on parking garages to be fair — lets me know I’m an inch or two away from can opening the truck
Robert LaBella
Robert
2023 Ford Bronco
I did exactly the same based on your suggestion. For whatever reason, the panel push retainer using that same product code looked different. As a result, it didn't quite fit and was a little loose. However, I also bought a variety pack of o-rings, found one of the smallest and shoved it into the antenna housing. After that, I inserted the panel push retainer and it fit like it was made to be there. Thanks for the great suggestion!
Ford Bronco Antenna Delete Screenshot_20231101_130316_Photos
Ford Bronco Antenna Delete Screenshot_20231101_130259_Photos
