Anyone have pictures of the stock harness that plugs into the sub? Not the one that plugs into the factory B&O amp?
Sounds Good Stereo has an adapter for Ford trucks with B&O systems that plugs into the sub harness and then has RCA outputs to plug directly into an aftermarket amp. They just need to verify which harness comes on the bronco.
This would let you add an aftermarket amp / sub without any splicing and no need for something like a LC2i. Just run power from the battery to the back of the truck and use the ground in the truck and everything else is plug and play.
https://soundsgoodstereo.com/produc...y-subwoofer-connection-harness-oval-subwoofer
