Anyone using a bike rack w/ their Raptor?
'18 M2
2023 Warthog
I’m looking at any/all hitch options, does anyone here had any suggestions? I’d like a four bike solution.
swamp2
I'm going to get a Kuat Thule (typo) swing out hitch system and a QuikrStuff tray style rack. Kind of like this:
https://www.bronco6g.com/forum/threads/1up-bike-rack-kuat-pivot-curt-hitch-sasquatch.33672/
Except QuikrStuff instead of 1Up. The inventor of the 1Up system left the company, totally redesigned the rack and started Quikrstuff. I've had multiple 1Up racks for years and they are "heirloom quality" and always a joy to use.
Quikrstuff shown in 1st two pics and 1Up on my 911.
Buy once, cry once...
Ford Bronco Anyone using a bike rack w/ their Raptor? quickrstuff-15-rotated
Ford Bronco Anyone using a bike rack w/ their Raptor? quickrstuff-19-rotated
Ford Bronco Anyone using a bike rack w/ their Raptor? PXL_20221026_012158540
'18 M2
'18 M2
2023 Warthog
I'm going to get a Thule swing out hitch system and a QuikrStuff tray style rack. Kind of like this:
good stuff, thanks. i’m concerned that the thule pivot won’t fit under the 37” tire. i’m definitely interested in the quickrstuff rack, that looks really well designed and machined.
swamp2
^ Ugh, sorry, Kuat swing hitch, like the linked post on the forum, NOT Thule. Brain fart...
Wheelin72
With the spare tire hanging over the hitch receiver, it gets in the way of my bike rack. I bought a hitch extension like one of these. Getting one with a "drop" will lower the bike rack (or trailer tongue) lower to the ground, which helps if you have sasquatch or a lift.
https://www.amazon.com/hitchextension
For the bike rack, I have an Allen 4 bike like this one...
https://www.amazon.com/Allen
If you pull the pin, the bike rack pivots rearward away from the vehicle about 45 degrees. I can fully open the bronco swing gate without removing the bike rack, which is AWESOME. This is a must-have feature.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
I also bought a hitch extension. I got the Thule one with bolt style pin to tighten and reduce the rack wobble.
I also have the Kuat 4 bike rack that tightens in the receiver to reduce wobble but it’s not my favorite and I’ve had bikes come loose so I would say the 1up route is a better option as it secures tires better.
'18 M2
'18 M2
2023 Warthog
From what I understand, using these hitch extenders lowers the weight rating of the rack.
85crawlrunner
Josh
Southern Utah
21’ Wildtrak
The extender is super stout and I see no problem at all with weight rating for 4 bikes being an issue.
If I were towing a trailer at full limit I would certainly check ratings for an extender but a bike rack is no way going to be a problem.
Wheelin72
I agree that a bike rack, fully loaded with bikes, is no problem on either the bike rack, the extension, or the tongue load onto the vehicle. I also use a motorcycle carrier/rack, with a motorcycle that weighs about 225 lbs. No issues.
Use of an extension DOES reduce the tongue load capability of the vehicle / receiver. The tongue load of the bronco is rated at 300 lbs. That load is assumed to go "straight down" at the point of the receiver. When you extend the receiver away from the vehicle, now the tongue load is pressing down, as well as creating a moment arm, or bending load at the receiver, and this reduces the amount of vertical tongue load that it can handle. So I've used the extension with my 225 lb motorcycle without issue. A fully loaded bike rack is far less than this.
For anti-wobble / rattle of the extension into the receiver, and bike rack into the extension, I use these devices...
https://www.amazon.com/hitch_tighten
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
I have the Kuat pivot V2 arm on my raptor, fitted to the quikrstuff mach2. The kuat pivot arm has literally like 5mm of clearance to the 37" tire. Its perfect. Opens 120-degrees. Build very solid.
Highly recommend that setup
604Bronco
British Columbia
www.bronco6g.com
'18 M2
'18 M2
2023 Warthog
You addressed the main issue I was concerned about with that set up- clearance on the 37” tire, thanks.
Obiwan
Southwest
Don't care to share personal info
Pics of said setup? I have been considering the Kuat V2 for my Thule rack but was concerned about clearances. I presume it also blocks the parking sensors.
Also seems like if you want to fully open the tailgate and have a slide floor, etc you need the version that swings out towards the drivers side NOT the passenger side
Thanks
swamp2
Also seems like if you want to fully open the tailgate and have a slide floor, etc you need the version that swings out towards the drivers side NOT the passenger side.
Yes, but due to the bike rack itself, not the Kuat swing bar.
Obiwan
Southwest
I think the issue is the pivot point on the swing bar actually, regardless of which bike rack. Kuat does offer it in either a passenger or driver orientation.
If I'm missing something please elaborate.
