good stuff, thanks. i’m concerned that the thule pivot won’t fit under the 37” tire. i’m definitely interested in the quickrstuff rack, that looks really well designed and machined.I'm going to get a Thule swing out hitch system and a QuikrStuff tray style rack. Kind of like this:
https://www.bronco6g.com/forum/threads/1up-bike-rack-kuat-pivot-curt-hitch-sasquatch.33672/
Except QuikrStuff instead of 1Up. The inventor of the 1Up system left the company, totally redesigned the rack and started Quikrstuff. I've had multiple 1Up racks for years and they are "heirloom quality" and always a joy to use.
Quikrstuff shown in 1st two pics and 1Up on my 911.
Buy once, cry once...
From what I understand, using these hitch extenders lowers the weight rating of the rack.With the spare tire hanging over the hitch receiver, it gets in the way of my bike rack. I bought a hitch extension like one of these. Getting one with a "drop" will lower the bike rack (or trailer tongue) lower to the ground, which helps if you have sasquatch or a lift.
https://www.amazon.com/hitchextension
For the bike rack, I have an Allen 4 bike like this one...
https://www.amazon.com/Allen
If you pull the pin, the bike rack pivots rearward away from the vehicle about 45 degrees. I can fully open the bronco swing gate without removing the bike rack, which is AWESOME. This is a must-have feature.
The extender is super stout and I see no problem at all with weight rating for 4 bikes being an issue.From what I understand, using these hitch extenders lowers the weight rating of the rack.
I don’t have a Braptor, but I love my Kuat Pivot V2 - I did a write up here, which might be helpful:I have the Kuat pivot V2 arm on my raptor, fitted to the quikrstuff mach2. The kuat pivot arm has literally like 5mm of clearance to the 37" tire. Its perfect. Opens 120-degrees. Build very solid.
Highly recommend that setup
You addressed the main issue I was concerned about with that set up- clearance on the 37” tire, thanks.I have the Kuat pivot V2 arm on my raptor, fitted to the quikrstuff mach2. The kuat pivot arm has literally like 5mm of clearance to the 37" tire. Its perfect. Opens 120-degrees. Build very solid.
Pics of said setup? I have been considering the Kuat V2 for my Thule rack but was concerned about clearances. I presume it also blocks the parking sensors.I have the Kuat pivot V2 arm on my raptor, fitted to the quikrstuff mach2. The kuat pivot arm has literally like 5mm of clearance to the 37" tire. Its perfect. Opens 120-degrees. Build very solid.
Yes, but due to the bike rack itself, not the Kuat swing bar.Also seems like if you want to fully open the tailgate and have a slide floor, etc you need the version that swings out towards the drivers side NOT the passenger side.
I think the issue is the pivot point on the swing bar actually, regardless of which bike rack. Kuat does offer it in either a passenger or driver orientation.Yes, but due to the bike rack itself, not the Kuat swing bar.
