Anything not obvious I'm missing for audio install?
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
Just for reference, here's a crossover calculator, you can ignore the lowpass, put in the frequency you want to crossover at and remember, it's just a 6db filter with just a cap so you probably want to go higher than you would think. The stock cap is 100uf which is around 400hz
https://www.omnicalculator.com/physics/crossover
I would personally buy a higher end capacitor such as these for audio use:
https://www.parts-express.com/speak...ylene-crossover-capacitors/capacitance/100-uF
They're significantly more expensive but garbage in/garbage out IMO. You can really up the sound of your speakers using quality components.
Changing to a second order will make it a 12db slope and decrease the amount of bass going through significantly, it does require adding a coil which increases cost, however. I'd probably build the crossover in the kick panel or somewhere other than the dash for ease of installation, even the larger, "real" audio cap is going to be maybe too big to fit up there if you go that route.
broncoToBe
Not a Bronco
Also, will I need any speaker wire?
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
If you're running new wires from the amp, yes. If you're using the existing connections, no.
JR
Bschurr
NY
JBMas
Bret
Mt Zion
Bronco Badlands Squatch Lux
Can you install the amp without an A2B dsp to translate factory head unit signal?
broncoToBe
Not a Bronco
I think so? I bought it from plugnplay kits with the harness, so I'm hoping it's literally plug and play
JBMas
Bret
Mt Zion
I’ve been researching my upgrade for a few months and far from expert. However my understanding is that the head unit speaks a different digital language and you need a A2B dsp to translate like Zen or metro. This video goes really deep but discusses it.
let me know, I have an install date next week and bought a Zen that I’m not using bc going with metra. I will be selling the Zen
broncoToBe
Not a Bronco
Also, I want to mount the amp by the rear wheel well, behind the panels. I've seen many pics with them mounted there but... How exactly is it fixed in place there? Is there like a standard screw formation where I can screw in anything? Velcro? Something else?
TXBronco72
Magnolia, Tx
F250 / 4D ‘23 Wildtrak
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
It's really, really easy, actually, you just need to pry with the right tool at the right place.
I uploaded this video to Youtube last week:
JR
Can you send a link to the filter / adapter you showed us?
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
