- #16
well you have years of people before broncos with 4 runners , jeeps and various other trucks using them under the hood and I've seen very little in the way of damage resulting from heat output. The bronco does have heat protection under the hood so while I'll say its not the best location , it is the cleanest and less noisy location. With what people including myself are spending on off road vehicles , if a 700 dollar compressor was my breaking point , then I think I have more to worry about than a 700 dollar compressor. If I have to replace it every 2 years , I'll be happy. I'll go on the beach maybe 10 to 20 times of the year. Doubt I'll do anything else that requires its use , so under my use and application , realistically , it should be fine. We shall see. Hopefully it gives years of service.ARB compressors have been around for a long time. So I’d say they were not “designed”for this location. They are high quality, heavy duty for sure and mine gets very hot when in use installed inside the bronco. Exposer to heat, water, DUST and whatever u might run into is gona have a high impact on the unit. I feel this was an easy location for company’s to create a bracket for. It’s an easy install also being so close to the battery. Noise? Well off-roading isn’t clean or easy.
