- Adam
- Aug 30, 2021
- 355
- 4,383
- 5,844
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
For those who have been looking to utilize the wires left by Ford behind your HD Modular Bumper to control some fog lights, we've got some harnesses coming soon.
Now, if you are not familiar with what we're talking about... basically on vehicles (most of them anyway) equipped with the HD Modular Bumper, there are no fog lights. You install them aftermarket (and we've got lots of options). However a few folks found that Ford actually left some pigtails behind the bumper (which are used for factory fogs on other builds). So a few smart folks did some digging and learned that you can buy a new headlight/fog light switch panel for your dash (replaces the factory one) and then do a bit of programming in FORSCAN (a program that lets you change settings and variables in the computer), connect these pigtails and now you can control a set of lights from your dashboard. JUST like from the factory.
There is a long thread here which goes over all of this. It's recommended if you are not familiar with this to give it a read:
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/
We've put together 3 harnesses to cover almost all of the lights you'll need. They are coming soon but available for pre-order from our site.
Each one is 20" (so you can reach any of the fog lights, especially if you run a triple fog light kit from us). One end has the connector installed for the light (plug and play) and the other end has the Ford connector. So you just plug it in, do some programming and swap in your new switch panel from Ford. It's a pretty easy process once you get the right switch panel (see that thread for info).
CrystaLux DT 4-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
https://www.4x4truckleds.com/crysta...il-pair-2021-ford-bronco-w-hd-modular-bumper/
CrystaLux DT 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
CrystaLux WP 2-Pin to MX150 Pigtail, Pair (2021+ Ford Bronco w/HD Modular Bumper)
The DT 4-Pin version is used on lights such as the Diode Dynamics SSC1, SSC2 and SSC3 w/BackLighting. It has the back-light control wire on it.
The DT 2-Pin version is used on lights such as the Diode Dynamics SS3 (without backlight), Rigid D-Series, KC HiLITES Flex, etc...
The WP 2-Pin version is used on Baja Designs S1, S2, Squadron lights.
