B&O and Base Speaker Size and Location
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I did get a separate one for the sub.
Curious if you can list out everything you had installed? I'm planning a similar system but probably with an AudioControl amp. Still unsure on the speakers.
Did you keep the sub in the stock location?
rguest3
Raymond
Florida and Virginia
F-350, F-450, 2022 Bronco, (2) 77 Broncos
Has anyone found a replacement Speaker Box/Enclosure for the Rear Roll Bar Speakers?
JFelty
Minnesota
Mustang Mach E
rguest3
Raymond
For me, the DV8 Bar would block the rear view too much.
Looking for Single boxes similar to stock, just a little additional room for a little bit larger speaker. They may need to be custom made?
rguest3
Raymond
OK, I can't find the 2 remaining speakers to bring the total count up to 10 as Ford advertises for the B&O System. What am I missing?
3 - Dash - Corners and Center
2 - Kick Panel
2 - Roll Bar
1 - Woofer Passenger Side Rear
8 is my Total
bradcd
Brad
Saab 9-3
2 - Kick Panel
2 - Roll Bar
8 is my Total
Maybe they're counting the dash left and right corner 2-ways as 4 total?
rguest3
Raymond
There ya go
LABlueBronco
Louisiana
2001 Jeep TJ on 37" SSRs and 2010 Silverado
2 - Kick Panel
2 - Roll Bar
8 is my Total
5 in the dash, tweeter/woofer combo in each corner.
ou812545
Dan
Livermore CA
BMW E60 M5
I have a Helix V Eight DSP amp being installed in mine and am replacing every speaker with the Audio Frogs, including the sub. I'm very underwhelmed by the B&O system, I can't imagine how bad the base system must be, although I see plenty of negative comments about it.
I'm looking at the Helix v8 as well. I want a complete stock look. I have the OBX High package and I also purchased the B&O sub enclosure to add a JL Audio 8W1 sub. I was hoping the Helix could power the entire system and sub but from what I have read the channels cant be bridged. Any way you can post some pictures or both amp installation locations? Also did you add anything to sum up or flatten the signal coming from the head unit to the Helix? Thanks
mortgagebruce
Bruce
Kansas City, MO
2016 Rubicon Hard Rock (SOLD) / 2020 Porsche 911
There wouldn't really be anything to see in the pictures. The Helix was installed behind the panel that is in the space behind my rear seat, but before the factory sub enclosure. Looks completely stock, you'd have no idea anything additional was behind it. I've got a 2-door, so I'm not sure how different it would be on a 4-door, although I'd suspect you'd actually have more room.
BONK
Ben
Central IL
2021 Bronco WT
Rockford...Fosgate. Uh, ok. :rolleyes:
In other news, the kick panel location has a cutout in the sheetmetal for a 6.5" round. Are you planning on cutting the sheetmetal to fit a 6x9?
What kind of speaker depth is allowed on the kick panel 6.5? Trying to decide on speakers.
josh1121
Josh
Riverside, CA
Nissan Titan XD Diesel 4x4, LandRover Defender 110
Anybody know the volume of the stock B&O sub enclosure?
Ninjak
Miami
2021 GT500 2021 Bronco Badlands 68 GTA
I have the B&O system, and it sounds pretty decent. I had a B&O in my Harley F150, and though I do not think the bass is as good, I do think it still sounds pretty good. I have the soft top, so perhaps after I do a few more things, I will address the audio. But for now, I am pretty happy with the B&O
josh1121
Josh
Riverside, CA
Trying to find the same, we’re you able to find the answer?
No answer yet, when I pull it out, I’ll fill it with water and figure it out.
