So the Comp R fits the B&O enclosure without much modification? I thought everyone was using the Comp RT because it’s so much shallower. I’m looking to upgrade my sub with a key 500.1 and kicker 8”, but I’m a bit confused between the R and RT and the 2 and 4 ohm versions. Thanks for all the info in this thread.I’ve seen others modify the enclosure. I chose to go with the kicker that I knew from others experiences would fit without modifying the enclosure. The problem I had with that was that the raised sections are hollow, so it’s not as simple as just removing the raised sections (there are three raised hollow sections on the enclosure that would need to be modified)
