Baja Design Fog light Bracket
jatt143
BRaptor, C63s, Defender 110
Hi All,
Any idea who sells just the modular bumper fog lights bracket?
Ford Bronco Baja Design Fog light Bracket 1647020915364
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hi All,
Nobody. Dealers cannot/do not sell Baja's bracket alone. It's only available as part of the kt.
With that said, we did develop our own version of this that works with both Baja Designs and Diode Dynamics
Kit w/Baja: https://www.4x4truckleds.com/baja-d...ad-bezel-flush-brackets-for-2021-ford-bronco/
Kit w/Diode: https://www.4x4truckleds.com/diode-...ad-bezel-flush-brackets-for-2021-ford-bronco/
Brackets Alone: https://www.4x4truckleds.com/kr-off-road-bezel-flush-triple-fog-light-brackets-for-2021-ford-bronco/
Ford Bronco Baja Design Fog light Bracket 1647021849907
NatureMan
United States
@4x4TruckLEDs.com , do you have plans on making these brackets for 2021+ f150 similar to the baja design kit? I prefer diode dynamic for SAE pods.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
jatt143
jatt143
just what I was looking for .. I'm used to Baja Designs and love their lights how do you compare Diode to baja? is the output about the same?
Thanks
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Thanks
Baja Designs is better for off-road lighting. They have a longer warranty (lifetime) and better quality as far as housings (they can take more abuse).
Diode Dynamics has a better wide pattern (for street legal use) and is less expensive. But not as long a warranty (8 years).
Our bezel system was designed to work with both which is nice.
jatt143
jatt143
@4x4TruckLEDs.com Few questions
1. Does Baja Design Bracket Harness covers all six lights? its 2 pairs of cable with 3 ends on each cable?
2. What are these spacers?
3. I just need the bracket,harness and two pairs of s2 sport. any bf6 discount code i can use? the one in your sig doesn't work, I will be using my Squardran Pro from 4runner that i was using as ditch light
Ford Bronco Baja Design Fog light Bracket 1647905553951
Ford Bronco Baja Design Fog light Bracket 1647905230517
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our harness plugs into all 6 lights (3 pairs). It controls 3 pairs of lights from 3 switches (so each pair is on it's own switch).
The spacers are for the Baja Designs Squadrons. They have a shorter bracket over the Diode Dynamics ones so the spacer is required to drop the bracket down to the proper alignment.
Baja Designs and Diode Dynamics do not permit the use of coupon codes for their products. We offer a discount when you buy a complete kit, and that discount is already built into the kit price. But ala carte there is no discount built in.
jatt143
jatt143
@4x4TruckLEDs.com
I'm in a pickle on which bracket to go with. Can you please help decide which one is better? I will be going with four s2 pros and two Squadron pros.
Ford Bronco Baja Design Fog light Bracket 1653756343238
Ford Bronco Baja Design Fog light Bracket 1653756378995
Is this the correct harness for the modular bumper?
Ford Bronco Baja Design Fog light Bracket 1653756505726
Do you have a harness that can support two lights not three, as I will be plugging the 3rd light set into the factory harness/switch? I guess no harm in spare cable dangling but wanted to see if you have a solution?
Ford Bronco Baja Design Fog light Bracket 1653756596364
4x4TruckLEDs.com
Adam
Lindenhurst, NY
@4x4TruckLEDs.com
Go with the flush mount. UNLESS you want to run 2 or 3 larger lights. The flush mount is SOOO nice and SOOO much easier to install. It's our favorite. The only downside is you get 1x 3" and 2x 2" instead of 2x 3" pods. But it's such a nice kit and so easy to install.
If you get the Baja Designs lights, you get the WP 2-pin yes that you linked.
We don't make a dual light harness, only a 3 pair harness (we run into this with Gen1 Raptors which only have 2 pairs). So you just tape off the 3rd pair is all.
jatt143
jatt143
Thank you! Ordered just now, sorry I didn't read the above comment. that $20 cable is free with the order? if so can I get that refund? :)
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Freebies aren't valid during holiday sales
