Base - Only one rear tow hook?
Scott R Nelson
Scott R Nelson
Meridian, ID
That's not a strong thing either and should be considered only for winching and not kinetic work.
I don't have a kinetic rope, so no problem. I have a 20-foot tow rope and two soft shackles and have watched enough off road rescue videos to know that you don't do any jerking at all with what I have.
As with the chains that I have for my Escape, I'm hoping to never have to use the tow rope either.
chtucker
Kirkland, WA
FJ Cruiser
They drag over rocks anyways.... first thing to hit when coming off a ledge.
Lifeliberty
Moonbeam👀
Columbus, OH
PSUTE
Western Maryland
Sierra
Reason I'm looking at a hitch...
Fmuguira
Frank
Idaho
Jeep TJ
Yeah, $48 for one stinking hook!!
I d find an aftermarket one and figure out a way to mount it ! 👍
Scott R Nelson
Scott R Nelson
Meridian, ID
I got the new tow hook today from the Ford dealer and installed it. Paid for with Ford Pass Point, so I consider it the same as being free.
I asked the parts guy what the bolts should be torqued to and he had a hard time finding that value. One place indicated 35 foot-pounds and another 55. I figured I would see what it took to loosen the bolt and it was right around 55, so that's what I used to tighten it back up. I hope it wasn't a mistake to use red Loctite on it, since that's all I had. Looks like the old bolts had blue.
Anyway, I now have two tow hooks both front and rear.
Ideally I'll never use them, but if the need arises I have them.
VAtruck
I asked the parts guy what the bolts should be torqued to and..
Use the standard value for the bolt diameter from a torque chart.
