Best / Cleanest Dash Cam Setups?
McRightclick
Idaho
2026 Badlands 2DR 7MT
Looking to get a front dash cam set up for my 26 Badlands (no auto dimming mirror), rear would be nice to have but not a necessity for me.
Is there a general consensus for the least obtrusive setup available, or are they all about the same? I don't plan to use all 6 auxiliary switch slots, can I wire in a 5V converter and draw straight from there?
Smocaine
DFW, TX
Cervelo Caledonia
I think the Mangoal can be used without having auto-dimmer and has a rear option. I don't believe any aux is required as it piggybacks off one of the plugs inside the overhead console.
If you go that route I would try to get the "new" version with the STARVIS 2 sensor - clarity is noticeably better, as the old one claims 4K but the sensor doesn't actually output it, so any 4K footage is simply upscaled.
I don't have any experience with it, but yeah, Mangoal would be my vote for "cleanest".
Wolfbox would probably come in a close second
McRightclick
Idaho
I like the look of that one a lot, do you know if there's a separate listing for the new one with the better sensor? I only see one option and it seems to have the base STARVIS
Smocaine
DFW, TX
Cervelo Caledonia
Not sure about Amazon but their own site has the STARVIS 2 units under a separate heading.
helifino16
Ron
Mount Sinai, NY (Long Island)
Have a look at this Forum entry for the Fitcamx. This is how I'd go if I had to do it over.
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
I have been happy with my Wolfbox G900 pro it’s just the two camera set up but works well. The only downside side is some of the mirror screens are darker than others, I have a dark screen so it’s like having limo tint in the back but I don’t really mind. The image quality is much better than my old iPhone 7 could capture. The pic with two mirrors is showing the difference between the factory mirror and the Wolfbox
Ford Bronco Best / Cleanest Dash Cam Setups? IMG_3301
Ford Bronco Best / Cleanest Dash Cam Setups? IMG_2994
railfan
Heber Springs, AR
2026 Outer Banks
I recently installed a Wolfbox 900 Tri-Pro Cabin. I love it. Great having the front facing dash cam directly in the mirror. Then the remote rear I installed just behind the rear glass. While the rear cam is rated for outside, I like it behind the rear window so that I can keep it clean with the wiper/washer. I have a rear digital camera in my 2020 Highlander. When it is raining, it gets difficult to see. This setup fixes the problem with road grime. Having it hardwired, it will also monitor the surrounding area when I'm parked (it takes images every second (configurable)). I wish I had a parking lot camera when someone backed their truck onto my Solara hood. My next update will be to add an additional mount on the rear roll cage so when I take the rear roof off, I can move the camera to the roll cage.
McRightclick
Idaho
I got in touch with Fitcamx's customer support and they said it doesn't have an option to power from the lane keeping assists cable, only the dimmable mirror (which I don't have) so that one appears to be a no-go.
LVS
Audi TT
I thought the Mangoal version used the Lane Assist connectors
McRightclick
Idaho
Mangoal does, Fitcamx doesn't, so I've already decided on the Mangoal. Just agonizing over whether or not I need the rear cam now too 😂
