Broncolli
MD
'21 Back Diamond 4 door MIC
Interesting, I am thinking maybe purchase one of these and have someone sew in a 2 inch strip, or one inch on either side to “stretch” it out. Rather than make it from scratch.
Jeverall
James
Tampa fl
Jeep Grand Cherokee
Nice! I was considering the same. The only thing different was instead of that tonneau cover I was going to look into one of those metal security closures from Diobolical. I wasn’t a fan of removing / replacing the rear windows. I also always liked the look of the Hummer SUTs, so wanted to create something similar look with removable top. I took a discarded soft top and modified the rear piece to Velcro across the back of my tonneau cover and Velcro across the top roll bar . A local upholstery shop advised they could make it look super clean with buttons around the entire frame for $250.
timhood
Tim
Several
Bikini top, Jeep windjammer, and Bronco vinyl tonneau.
Ford Bronco Bimini Top, windjammer, and  tonneau cover setup. Rainproof for most part 86FE9CB8-D4AB-4B04-A7C0-4E69A72EA7EA
Came to see a bikini top. Disappointed that all I saw was a Bimini top, so leaving this for others. You're welcome! 😉
Ford Bronco Bimini Top, windjammer, and  tonneau cover setup. Rainproof for most part IMG_3067
Deebocubs
Deebocubs
Chicago
Bimini Top is right. Bikini is for two door or above 😂
timhood
Tim
Several
While we're discussing, have you noticed how the doors are bigger on the two-door? 😁
Nosnowgo
Daytona Beach
Bronco; Wrangler
Have not experienced a full major storm yet. Just some normal rain. Nothing came in while driving.
The back tonneau puddles so I need to create some type of support bar. Some water got in the trunk but nothing major.
Nosnowgo
Daytona Beach
Bronco; Wrangler
Bestop 8003315 Wrap-Around Windjammer for 1997-2002 Wrangler
RERPRO Trunk Cargo Cover for Ford Bronco 2021 2022 4 Door Rear Trunk Security Shield Shade Luggage Tonneau Cover
I love your set up. But I can't find a tonneau cover anywhere by RERPRO like the one you have here with the straps all inside the Bronco so the tail gate can still open. Do you have an actual link to where you bought that? Any help is greatly appreciated!
sage729
Ian
Maryland
4dr Big Bend soft top, Area 51, non SAS, mid pack
Could you take a few pictures of how the window is attached at the top and bottom? I love that you repurposed a back window, very smart!
Deebocubs
Deebocubs
Chicago
Nosnowgo - I modified the RERPRO top and cut the straps off. The Rampage Trailview fastback top I bought has a channel that I repurposed with the RERPRO top. That allowed me to get ride of the straps and seals nice. Completely seals and rainproof. I have learned that the sides don’t seal well with the Velcro. It’s sad that Rampage doesn’t care to make the tonneau cover even thought the have parts from the Trailview fastback that seal nicely on the sides and back so it’s only a Matter of fabricating the cover. Seems like it would be an easy win for them since they solved the hard part making it waterproof. When I emailed Rampage they had no plans on creating the tonneau. I would be first in line to buy it and even test it out. The Rampage top worked out very well this past summer and the quality held up. No issues. Sorry for the delayed response here.
Frappy608
NorCal
2022 Badlands Eruption Green
hey @Deebocubs, wondering if you experimented at all with the different wraparound windjammer options as there are several different models for different jeep models. Wondering which one fits best!
Deebocubs
Deebocubs
Chicago
I didn’t explore other options outside of the Bestop 8003315 Wrap-Around Windjammer for 1997-2002 Wrangler. I didn’t want big gaps between rollbar and fabric and this one seemed the largest one that was close enough to the Bronco spec's so it works good enough.
madfella
El Paso, Texas
2022 Ford Bronco
Which windjammer is this? This looks like it will work for my setup.
