zyglyrox
Cory
Cleveland
‘22 BaseSAS / ‘21 Bronco Sport BB
So what's that graph look like below 2,000 RPM?
Probably still improved, just hard to dyno with RPM so low
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
This relates back to the old days when you would swap intake manifolds. Lengthening the intake runners adds low power torque and shifts the power band lower into the rpms. With the 2.3 being such a low rpm engine it looks like the shift doesn't hurt the top end on the dyno. Typically mods like this do not add power overall. Very happy someone spent the time to see if it worked.
Rusty Sheckelford
Rusty
LA
I don't know if a Roomba really needs a racing intake manifold, but I'm here for it!
Boomba Racing
Boomba Racing
Lux Sponsor (Level 2)
Boomba Racing
Wood Dale, IL
www.boombaracing.com
BRONCO
Do you have coming installation instructions specifically for the Bronco 2.3?
It is something we still have to do, the installation is very simple there is a good amount of room in the engine bay and both the IM and TB Spacers fit perfectly with no issues.
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
Would you expect similar results with the Ford Performance tune already installed?
The gains would actually be even greater with any other tune than the OEM one. This was with 100% bone stock vehicle, no intake or bolts parts. We wanted to get the most accurate results without any other mods skewing our numbers.
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
Was this with stock intake? Would a bigger intake have a negative effect on this or is it only potential regardless of other mods?
100% stock intake and stock vehicle. Quality bolt-ons mods should have a positive effect and help increase the numbers even higher.
Boomba Racing
Boomba Racing
Boomba Racing
Wood Dale, IL
BRONCO
Ford really underrated these 2.3 engines, they make really great power and the low end torque makes it extremely easy to drive manual (especially in traffic). We did tons of baseline pulls before throwing on the parts to make sure the numbers we got were consistent.
adcam
Mando
2021 Bronco 4DR 2.3L
So you are saying if I had the FP tune, this spacer would not be worth it?
Aman
Aman
Northern NJ
I believe they tested this with the stock tune and are stating that any performance tune, including Ford's, will be even better.
FreddieLee
Freddie
When do you project this being available for the 2.7L?
nolimits
22 Explorer ST | 23 Challenger SP 1320
Watching for a 2.7 option
adcam
Mando
But read the first sentence. “The gains would be even greater with any other tune Than the OEM one.
